gbeddow
Feb 19, 2016Luminary
build external kernel moduel?
I'm looking for help with building an external kernel module - both in general and, in particular, for the AX88179 USB to Ethernet adapter - with ReadyNAS 6.4.2 on an RN202. Here's a condensed ve...
- Feb 23, 2016Found a solution.Turns out ReadyNAS 6.4.2 for the RN202 already includes the driver (external module) for the AX88179 USB to Ethernet adapter (also sold by j5create as the JUE130), but out of the box the kernel needs to be configured for it:
# cd /home/gbeddow/linux_src/linux-4.1.16-alpine # make menuconfig Device/Drivers -> Network Device Support -> USB Network Adapters (press "M" to enable as module) (EXIT AND SAVE CONFIG) # make ... CC drivers/net/usb/ax88179_178a.mod.o LD [M] drivers/net/usb/ax88179_178a.ko ... # mkdir /lib/modules/4.1.16.alpine.1/kernel/drivers/net/usb (COPY THE MODULE AND ITS DEPENDENCIES SO MODPROBE CAN FIND THEM:) # cp /home/gbeddow/linux_src/linux-4.1.16-alpine/drivers/net/usb/ax88179_178a.ko /lib/modules/4.1.16.alpine.1/kernel/drivers/net/usb/ax88179_178a.ko # cp /home/gbeddow/linux_src/linux-4.1.16-alpine/drivers/net/usb/usbnet.ko /lib/modules/4.1.16.alpine.1/kernel/drivers/net/usb/usbnet.ko # cp /home/gbeddow/linux_src/linux-4.1.16-alpine/drivers/net/mii.ko /lib/modules/4.1.16.alpine.1/kernel/drivers/net/mii.ko (ADD TO MODULES.DEP:) # vi /lib/modules/4.1.16.alpine.1/modules.dep /lib/modules/4.1.16.alpine.1/kernel/drivers/net/usb/ax88179_178a.ko: /lib/modules/4.1.16.alpine.1/kernel/drivers/net/usb/usbnet.ko: /lib/modules/4.1.16.alpine.1/kernel/drivers/net/mii.ko: # modprobe mii # modprobe usbnet # modprobe ax88179_178a # dmesg ... ax88179_178a 2-2:1.0 eth2: register 'ax88179_178a' at usb-0002:01:00.0-2, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:05:1b:b0:42:82 usbcore: registered new interface driver ax88179_178a # ifconfig eth2 up # ifconfig ... eth2 Link encap:Ethernet HWaddr 00:05:1b:b0:42:82 inet6 addr: fe80::205:1bff:feb0:4282/64 Scope:Link inet6 addr: 2601:643:c080:92:205:1bff:feb0:4282/64 Scope:Global UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:182 errors:0 dropped:0 overruns:0 frame:0 TX packets:41 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:63762 (62.2 KiB) TX bytes:12027 (11.7 KiB) ...
mdgm-ntgr
Feb 24, 2016NETGEAR Employee Retired
Thanks for sharing your solution. Not sure why you need 3 ethernet connections to the NAS though.
gbeddow
Feb 24, 2016Luminary
Investigating Intrusion Detection & Prevention Systems. Only 2 ethernet connections needed for Detection (typical Snort configuration), but 3 (or more) needed for Prevention.
