bullfrog1
Oct 31, 2011Tutor
compiling idle3tools under qemu for sparc
Hi I'm trying to compile idle3tools using the qemu development environment for sparc platform. At the moment it's compiling with warnings, however when I then run it on the readynas nv+ I'm also...
Baxxx1
Oct 31, 2011Aspirant
Hi Jeremy!
i also have two WD-drives with idle3 Problem (EARX 2GB). And as my Windows PC doesnt want to boot with the raid-drive connected, i thought about installing idle3 tools on the raid itself, too.
the problem you are facing could be that the drive /dev/hdc is not the physical drive, but the raid array (xraid, raid1, raid0).
so the question would be, if there are further block devices (/dev/sd?, /dev/hd?) which are accessible directly or if the hardware raid bocks access to those devices.
i will check at home after work.
greetings from Austria,
Baxxx
Baxxx
