bullfrog1
Oct 31, 2011Tutor
compiling idle3tools under qemu for sparc
Hi I'm trying to compile idle3tools using the qemu development environment for sparc platform. At the moment it's compiling with warnings, however when I then run it on the readynas nv+ I'm also...
Baxxx1
Nov 01, 2011Aspirant
Hi Jeremy!
did you try the same on /dev/hde ?
for your info:
dmesg tells me the following:
fdisk /dev/hdc
fdisk /dev/hde
so hdc and hde are the physical disks, but they are differently partitioned ?!?
it doesn't make sense to me ....
for me hde seems to be the "current disk", but no partitions on hdc?
good luck and thaks for your efforts!
Bax
for your info:
NAS:~# dmesg
X_RAID_DUMP
VERSION/ID : SB=(V:0.1.0) ID=<c7506636.00000000.00000000.00000000> CT:4ea4525f
RAID_INFO : DISKS(TOTAL:2 RAID:2 PARITY:0 ONL:2 WRK:2 FAILED:0 SPARE:0 BASE:1)
SZ:3907008688 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:3907008686
LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:1:000000000 DM:3
LOGICAL_DRIVE : 1: B:0004096002 E:3902912686 R:1 O:1 I:1:000000000 DM:3
PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST:P :online>
PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:3907008688,ST: B:online>
CURRENT_DRIVE : DISK<N:0/1,XXX(22,0),ID:0,PT:1,SZ:3907008688,ST:P :online>
CURRENT_DRIVE : DISK<N:1/2,XXX(33,0),ID:1,PT:1,SZ:3907008688,ST: B:online>
RUN_PARAMETERS: raid_running=1,last_word=ok,interface_start_at=1,fake=0
RAID_REBUILD : sync=0,logical=0,parity=1,sectors/TOTAL=0/4294967295
: source=1, total_drives=1, auto_sync=1
RAID_P_CHECK : chck=0,logical/total=0/2,raid_level=0
: err/sectors/TOTAL=0/0/0,report_err=1
: initialized=0x3,initialize_error=0x0,initializing=0x0
: where=0,total=3907029168
SIZE_INFOR : sb_size=9440,sections_size=32/256,disk_t_size=128
: sb=f8140294,disks=512/1536,luns=2048/3168,thisdisk=5216/128,diskid=5344/4096
DJO_RECORD : dj_raid=NO_RAID,chns=0,source=0,disks=0 parity=0,chn_image=3,
: sectors=3498562/0x356242,need_IO=1
IO__RECORD : 0=166992,1=48414802,2=0,3=0, busy=0/0/1/0/0,t_d=3
fdisk /dev/hdc
NAS:~# fdisk /dev/hdc
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0x3b2ff3b9.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
The number of cylinders for this disk is set to 243200.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., old versions of LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): p
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x3b2ff3b9
Device Boot Start End Blocks Id System
Command (m for help): q
NAS:~#
fdisk /dev/hde
NAS:~# fdisk /dev/hde
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
Disk identifier: 0x00000000
/dev/hde1 1 255 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hde2 255 287 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hde3 287 243200 1951192152 5 Extended
/dev/hde5 287 243200 1951192151+ 8e Linux LVM
NAS:~#
Bax
