Thrass
Nov 13, 2013Aspirant
Compiling Kernel with snd-usb-audio for RN102 6.1.4
Hi, I bought this nas and originally it was a tradeoof for features and price, because I really would've liked to have one with audio capabilities... now I got this usb soundcard and a little bit ...
WhoCares_
Jul 27, 2014Mentor
The difference in version is most likely what is causing your problems. Did you use the defconfig.arm provided with the ReadyNAS OS sources as starting point for your own kernel config? If so, it *should* have set the modversions correctly for you. Strong emphasis on the *should* here for NETGEAR doesn't always supply a correct defconfig file for the ARM architecture. If I recall correctly, there's a defconfig.arm file floating around here on the forums. If that one doesn't work for you or in case you can't find it, let me know. I may have a working version somewhere.
-Stefan
-Stefan
