Phv211
Jun 27, 2019Aspirant
Delete Time Machine Sparsebundles
Hi To help those who have not solved the Sparsebundles removal problem Enable Timemachine AFP on the NAS Put the same password as the admin of the NAS Launch Terminal on Mac ssh NASIP (for examp...
Jun 27, 2019Guru - Experienced User
Phv211 wrote:type the command: su
enter the password of the NAS
Normally you should log in as root when you access the NAS with ssh. If you do that then su isn't needed.
- Phv211Jun 28, 2019Aspirant
Hi
Thanks for reply
Normally ... but nothing worked and the ssh login refused root and took the admin from the mac. With "su" it ended up happening.
