RudyReady
Sep 18, 2016Aspirant
Developer Request: Subsonic 6.0 for ReadyNas x86
Would someone be able to produce a .bin of the latest version of Subsonic (6.0) for x86? Thank you.
RudyReady
Sep 21, 2016Aspirant
Thanks for the reply; however, I have an Ultra 6 Plus which uses the RAIRar-x86 4.3.20 OS/firmware, not OS4 or OS6.
JennC
Sep 22, 2016NETGEAR Employee Retired
Hello RudyReady,
Is that 4.3.20 or 4.2.30?
- RudyReadySep 22, 2016Aspirant
It is 4.2.30, so I guess that makes it OS4 (thanks StephenB).
- JennCSep 22, 2016NETGEAR Employee Retired
Hello RudyReady,
ReadyNAS units are OS4, OS5 and OS6.
Firmware starts with 4 is ReadyNAS OS4, the one starts with 6 is OS6, there is also a firmware starts with 5, that is OS5.
You may check this discussion by the developer: https://community.netgear.com/t5/Community-Add-ons/Subsonic/m-p/780710#U780710
- JennCSep 27, 2016NETGEAR Employee Retired
Hello RudyReady,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- RudyReadySep 28, 2016Aspirant
JennC
It doesn't appear that Subsonic 6.0 Add-on install package for OS4 has been developed yet, but hopefully there is a developer out there who is interested in doing this.
- Aug 31, 2022Retired_Member
