vgoranov
Dec 20, 2015Aspirant
DNSMASQ add-on for ReadyNAS Duo
Guys, I would like to use my ReadyNAS Duo to boot diskless PC over the network (LAN). To do that I have to run PXE server on the NAS. After extensive research the only add-on which is close ...
vgoranov
Dec 21, 2015Aspirant
Thanks for the guidance StephenB. I will contact WhoCares_.
Do you have other suggestions on how to solve the problem with runnig diskless PC over LAN hosting the OS on the NAS?
Dec 21, 2015Guru - Experienced User
Unfortunately no.
- vgoranovDec 23, 2015Aspirant
Thaks anyway StephenB. I contacted WhoCares_ and his help was instrumental for me to make progress.
Happy holidays!
