Mhynlo
Mar 01, 2017Luminary
Docker CLI App for 6.7.0 (Work In Progress)
It looks like there are some handy changes in 6.7.0, so I tried to get a Docker CLI app to get the containers moved over into the apps directory (not root volume). https://community.netgear.com/t5/C...
OOM-9
Mar 02, 2017NETGEAR Expert
You can try downgrading to the Beta 2 to get the support for the Kernel Plus app. The fix for the 6.6.1 that was in the intermediate build will be kept when downgrading to the Beta 2 build. We try to make sure the the dependent package for Kernel Plus is available for the public betas.
- MhynloMar 03, 2017Luminary
It looks like Docker is changing their packaging over to a different repo and versioning. I have updated the latest package to work with the newer version.
I downgraded to beta 2 and I am able to run the latest docker.
Download available:
https://github.com/Mhynlo/readynas-docker-cli/releases/tag/17.03
- StephenBMar 03, 2017Guru - Experienced User
thx for keeping us up to date on your progress here. Docker support will be very helpful.
- MhynloMar 06, 2017Luminary
I am still looking into implementing the UI bit.
I looked at Potainer. It looks like they are partnering with Rancher, so time to look at Rancher!
