Mhynlo
Mar 01, 2017Luminary
Docker CLI App for 6.7.0 (Work In Progress)
It looks like there are some handy changes in 6.7.0, so I tried to get a Docker CLI app to get the containers moved over into the apps directory (not root volume). https://community.netgear.com/t5/C...
OOM-9
Mar 02, 2017NETGEAR Expert
You can try downgrading to the Beta 2 to get the support for the Kernel Plus app. The fix for the 6.6.1 that was in the intermediate build will be kept when downgrading to the Beta 2 build. We try to make sure the the dependent package for Kernel Plus is available for the public betas.
Mhynlo
Mar 03, 2017Luminary
It looks like Docker is changing their packaging over to a different repo and versioning. I have updated the latest package to work with the newer version.
I downgraded to beta 2 and I am able to run the latest docker.
Download available:
https://github.com/Mhynlo/readynas-docker-cli/releases/tag/17.03
- StephenBMar 03, 2017Guru - Experienced User
thx for keeping us up to date on your progress here. Docker support will be very helpful.
- MhynloMar 07, 2017Luminary
I am still looking into implementing the UI bit.
I looked at Potainer. It looks like they are partnering with Rancher, so time to look at Rancher!
- MhynloMar 15, 2017Luminary
I looked into the Rancher option, and it looks like that might be better suited with a server with more resources. Portainer is a little more lightweight and provides a lot of useful features/interfaces to docker.
I have set it up to require the Docker-CLI package to be installed since that handles all of the volume management for the docker containers. Portainer is running as a container within Docker, so they are tightly related.
Here is the Portainer release that works with the 6.7.0 betas:
https://github.com/Mhynlo/readynas-portainer/releases/tag/1.12.1
