Mhynlo
Mar 01, 2017Luminary
Docker CLI App for 6.7.0 (Work In Progress)
It looks like there are some handy changes in 6.7.0, so I tried to get a Docker CLI app to get the containers moved over into the apps directory (not root volume). https://community.netgear.com/t5/C...
Mhynlo
Mar 03, 2017Luminary
It looks like Docker is changing their packaging over to a different repo and versioning. I have updated the latest package to work with the newer version.
I downgraded to beta 2 and I am able to run the latest docker.
Download available:
https://github.com/Mhynlo/readynas-docker-cli/releases/tag/17.03
Mar 03, 2017Guru - Experienced User
thx for keeping us up to date on your progress here. Docker support will be very helpful.
- MhynloMar 06, 2017Luminary
I am still looking into implementing the UI bit.
I looked at Potainer. It looks like they are partnering with Rancher, so time to look at Rancher!
- MhynloMar 14, 2017Luminary
I looked into the Rancher option, and it looks like that might be better suited with a server with more resources. Portainer is a little more lightweight and provides a lot of useful features/interfaces to docker.
I have set it up to require the Docker-CLI package to be installed since that handles all of the volume management for the docker containers. Portainer is running as a container within Docker, so they are tightly related.
Here is the Portainer release that works with the 6.7.0 betas:
https://github.com/Mhynlo/readynas-portainer/releases/tag/1.12.1
