Mhynlo
Mar 01, 2017Luminary
Docker CLI App for 6.7.0 (Work In Progress)
It looks like there are some handy changes in 6.7.0, so I tried to get a Docker CLI app to get the containers moved over into the apps directory (not root volume). https://community.netgear.com/t5/C...
MrGamerChoi
Mar 18, 2017Tutor
Thx for the hard work! Keep it up mate.
Will try this out once I finished backing up my data. I screwed my Admin page up when I installed rutorrent on my 102 and I heard it may works fine under Docker. Will let you know if it works or not.
