mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
WhoCares_
Apr 22, 2014Mentor
I guess you tried installing the add-on via the command line which is not how it is meant to be done by Netgear. I wish Netgear would have listened and had chosen a different file extension for add-ons/apps. Anyway, the recommended way to install *any* add-on is to use the "Upload" function in the upper right corner of the "Apps" tab. This will check for and install all needed dependencies as well.
-Stefan
-Stefan
