mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
btaroli
Apr 22, 2014Prodigy
Well, I got around the transmissionr6 issue by invoking dpkg manually. ;)
Anyway, I did just use the upload function to install Dropboxmanager and, well I guess you could say the results were mixed. It reports success. But now the web UI for the NAS is dead and the Dropbox service apparently failed to start...
START(/tmp/dropboxmanager_1.0.2_amd64.deb): Tue Apr 22 12:10:46 PDT 2014
Hit http://apt.readynas.com 6.1.7 Release.gpg
Hit http://mirrors.kernel.org wheezy Release.gpg
Hit http://mirrors.kernel.org wheezy/main amd64 Packages
Hit http://apt.readynas.com 6.1.7/updates amd64 Packages
Hit http://apt.readynas.com 6.1.7/apps amd64 Packages
Hit http://apt.readynas.com 6.1.7/main amd64 Packages
Reading package lists...
new debian package, version 2.0.
size 106182 bytes: control archive=2637 bytes.
55 bytes, 2 lines conffiles
517 bytes, 13 lines control
3313 bytes, 41 lines md5sums
478 bytes, 18 lines * postinst #!/bin/bash
169 bytes, 7 lines * postrm #!/bin/sh
1361 bytes, 61 lines * preinst #!/bin/bash
183 bytes, 7 lines * prerm #!/bin/sh
Package: dropboxmanager
Version: 1.0.2
Architecture: amd64
Maintainer: ReadyNAS Xtras <xtras@readynasxtras.com>
Installed-Size: 388
Depends: libapache2-mod-wsgi, sudo, python-django, python-feedparser, python-sqlite, python2.7, wget
Found 7 dependants
pkg[1/7]= libapache2-mod-wsgi
pkg[2/7]= sudo
pkg[3/7]= python-django
pkg[4/7]= python-feedparser
pkg[5/7]= python-sqlite
pkg[6/7]= python2.7
pkg[7/7]= wget
Chking dependencies..
Depenency libapache2-mod-wsgi met
pkg[2/7]= sudo
Depenency sudo met
Depenency python-django met
Depenency python-feedparser met
Depenency python-sqlite met
pkg[6/7]= python2.7
Depenency python2.7 met
pkg[7/7]= wget
Depenency wget met
Section: misc
Priority: optional
Description: Dropbox Manager for ReadyNAS OS 6
The Dropbox Manager will install the latest binaries
of the Dropbox daemon on x86 based ReadyNAS systems. It
also includes a Django based web interface for managing
user accounts and daemon settings.
fv-dpkginstall.awk: success
Success install dependencies for /tmp/dropboxmanager_1.0.2_amd64.deb
Selecting previously unselected package dropboxmanager.
(Reading database ... 35872 files and directories currently installed.)
Unpacking dropboxmanager (from .../dropboxmanager_1.0.2_amd64.deb) ...
Setting up dropboxmanager (1.0.2) ...
insserv: warning: script 'automatic' missing LSB tags and overrides
No DropBox users defined!
invoke-rc.d: initscript dropboxmanager, action "start" failed.
dpkg: error processing dropboxmanager (--install):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
dropboxmanager
DONE(0): Tue Apr 22 12:11:08 PDT 2014
spooler returns spool_status=0 outbuf=(null) errbuf=(null) is_localapp=1 name=dropboxmanager_1.0.2_amd64.deb pkgname=dropboxmanager
