mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
btaroli
Apr 23, 2014Prodigy
Well, restart all wasn't helping. So I figured I'd start fresh, since previously I had no guide for what to expect when starting this thing. So I yanked out all Dropbox references from my user home dir, returned /etc/default/dropbox to it's virgin null status, and rebooted the NAS (no amount of killing was going to get rid of the original zombie/defunct process).
After startup I accessed the settings page and see:
I should point out that trying to apply either the newer stable or testing builds results in an error. No logging on that either?
Having cleared the config, starting the daemon for my user required linking again. No biggie. Once done the display changed to what I had previously seen. First it retrieved the file list and then began counting down as it syncs.
I've just checked again and it says retrieving file list again. Odd but I'll check it again in a few mins before posting this.
I'd love to see this working. Just not sure what to expect, and it's not clear whether I'm not following the non-existent manual or if there are actual problems.
Checked again and the page still says downloading list. Checked processes and the daemon's still running but appears idle. Maybe this is normal then? I guess I'll learn shortly...
