mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
mdgm-ntgr
Apr 23, 2014NETGEAR Employee Retired
Are you sure the files have all uploaded to Dropbox? I think folders get uploaded first then files?
Where did you add the file you wanted to sync, to a client PC to then sync to the ReadyNAS or to the ReadyNAS to then sync to other devices?
If to the ReadyNAS did you add it using SMB? AFP? Something else?
