mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
WhoCares_
Apr 23, 2014Mentor
btaroli wrote: Well, if you mean /data/Dropbox, for the "admin" setup I presume, then no. I never started that one so there's nothing at all in there, even now.
No, I meant /data/.dropbox (but not /data/.dropbox-dist and of course not /data/Dropbox)
btaroli wrote:
WhoCares? wrote:
btaroli wrote: I should point out that trying to apply either the newer stable or testing builds results in an error. No logging on that either?
Would have been nice to see the actual error message. But no, no logging on that either ;) But to give you a better understanding let me try to explain what is happening and also why I can't fix this.
On initial install, Dropbox Manager wil try to download the Dropbox binaries from the generic "stable" link provided by Dropbox, e.g. from here https://www.dropbox.com/download?plat=lnx.x86_64
As you can see this is an unversioned link and it *should* point to the latest stable release. Unfortunately Dropbox isn't very good at keeping these links current, that's why in most of the cases Dropbox Manager will install a version that is older than the one Dropbox Manager later on reports as being the current "stable" version.
Well, I did try a simple wget on this and got:
2014-04-23 12:36:05 (1.72 MB/s) - ‘download?plat=lnx.x86_64’ saved [24380314/24380314][/code]
So at this moment, at least, it is pulling 2.6.31 when accessed.
Fine, so they finally updated the generic link target. But I'm not sure I understand the relevance here.
btaroli wrote:
WhoCares? wrote: Which reminds me: what version of the Dropbox Manager app are you using?
The version the page gave me when I paid... 1.0.1
Would be nice if you could log in again and download 1.0.4 from the "My Account" page. I'm pretty sure I fixed something for downloading updates in 1.0.2 or 1.0.3.
-Stefan
