mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
WhoCares_
Apr 24, 2014Mentor
btaroli wrote: Well, I think I'm going another round with 1.0.4 re-install, since the dropbox daemon isn't dropping into the "downloading file list" status now, but it is getting stuck in the sync state at the same file count for hours and hours. And every single time I use the settings UI to stop/start (which I suspect is likely just running /etc/init.d/dropboxmanager), another defunct daemon is left hanging around.
Something is definitely *very* weird on your ReadyNAS. As much as I try, I can't reproduce *any* of the different behaviours of Dropbox that you're reporting. What version of ReadyNAS OS are you running? I'm using 6.1.6 and 6.1.7.
And sorry, I of course meant the /data/ folder, not /apps.
-Stefan
