mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
gibxxi
Mar 12, 2015Guide
It's not working on the OS6.2.3 Beta's either. If you install the latest version of DB Manager on those firmwares, at least on my legacy Pro running 6.2.3-T1751 it will totally b0rk the HTTP and HTTP/S services for the entire NAS. Access is still possible to the NAS via HTTP/S for Frontview, but the indicators remain "off" in the settings area. HTTP never re-lights even after an uninstall, which does restore HTTP connectivity for everything else.
OS re-install doesn't completely fix it either. Only option to completely undo the damage is a Factory Default.
