mdgm-ntgr
Apr 12, 2014NETGEAR Employee Retired
Dropbox for R6 (x86 only)
Those wanting a Dropbox add-on similar to the one for 4.2.x with support for bidirectional syncing of entire Dropboxes need wait no longer. Take a look at this great add-on by WhoCares?: https://rnxtr...
gibxxi
Mar 13, 2015Guide
...Of course, there may also be issues with the fact it had just started a full resync after I installed Dropbox. As I say this was a clean install of T1751 from the get-go. I had however downgraded from 6.3.3-T143 to the 6.2.3 beta (also because of this same issue) to see if it was an issue with compatibility with the newer 6.3.3 Betas.
