ooniell
Feb 01, 2017Aspirant
dropbox for ReadyNAS ultra 2 not snycing.
Hi, Every one. I bought the Dropbox app for a few weeks ago and have struggled really hard to get it to work. I have a ReadyNAS Ultra 2 x86 model that is running on RAIDiator 4.2.3 i ha...
Feb 01, 2017Guru - Experienced User
You might want to contact the app provider directly. If it's from https://rnxtras.com/ you can also pm WhoCares_ here (using the messages link in the upper right).
Dropbox also has their own forum, and it might be worthwhile to ask there.
Did you mean 4.2.30? If not, you are running ancient firmware, and you should update it.
- ooniellFeb 01, 2017Aspirant
well. i have searched the entire forum for this answears and contacted the developer in person and he won't respond
yhea sry i do mean 4.2.30. the latest
- StephenBFeb 01, 2017Guru - Experienced User
I've seen some other reports on subfolders not syncing. The developer is creating the install package, and the program itself comes from dropbox. That's why I suggested the dropbox forum.
Try also PMing him here though.
