Eckers
Oct 08, 2016Guide
empty resource error. bad nml call. code 22002010000
i'm getting the error above when i try to open the Plex app. it was working fine until this morning. is there a solution? thanks
Eckers
Oct 08, 2016Guide
Yes I have rn214 running latest firmware and latest Plex software. Do I just wait for Plex or Netgear to provide a fix? Anything I can do in the meantime? Thanks
mdgm-ntgr
Oct 08, 2016NETGEAR Employee Retired
For now you can wait for a fix.
- TwILeK1Oct 09, 2016Aspirant
Hi
Same error with readynas 104 ... os 6.6.0 ..
Why upload a firmware update if it is not working??
- StephenBOct 09, 2016Guru - Experienced User
It's a plex problem, they need to update their build to be compatible with Debian 8.
Hi
I think it's not a PLEX problem, because i try to start nas-transmisson :)
So i think it is a readynas problem :(
