Eckers
Oct 08, 2016Guide
empty resource error. bad nml call. code 22002010000
i'm getting the error above when i try to open the Plex app. it was working fine until this morning. is there a solution? thanks
mdgm-ntgr
Oct 08, 2016NETGEAR Employee Retired
For now you can wait for a fix.
TwILeK1
Oct 09, 2016Aspirant
Hi
Same error with readynas 104 ... os 6.6.0 ..
Why upload a firmware update if it is not working??
- StephenBOct 09, 2016Guru - Experienced User
It's a plex problem, they need to update their build to be compatible with Debian 8.
- TwILeK1Oct 09, 2016Aspirant
Hi
I think it's not a PLEX problem, because i try to start nas-transmisson :)
So i think it is a readynas problem :(
TwILeK1 wrote:
Hi
Plex says their current build won't run on your RN214. https://forums.plex.tv/categories/netgear-readynas
If your problem is with a different app, then start a new thread, giving the details of your app (including where you downloaded it from).
