vrspectre
Aug 31, 2016Apprentice
Encrypting to Amazon Sync
So I finally got my Amazon Sync working and it's currently uploading my first 1TB. Yay!! However, I got to thinking about security. There's a clause in the amazon terms of use that says they can ...
vrspectre
Sep 01, 2016Apprentice
lots to reply to.
I want to use a cloud backup because it's offsite. I'm backing up important family things like photos and family documents. Nothing hugely interesting to someone specifically targeting me, but valuable to someone who gets my data as let of a larger breach.
I'm not a business, this is just for home use so I do not really want to buy another nas and put it in a data center on the other side of the country. I'm confident in my local backup solution, but what if my house burns down, I would hate to lose all that stuff.
I would just use readynas vault, but I'm looking for a more cost effective solution. 2tb with the vault is $40 per month where Amazon is $60 per year. Huge difference.
Maybe I just need to be less of a cheap **bleep** and pony up for readynas vault....
Sep 01, 2016Guru - Experienced User
Sync isn't really a backup anyway, since any problem with the NAS files ends up being applied in the Amazon Cloud
Crashplan would also cost $60 per year for a single device (unlimited storage). It is encrypted.
It is possible to to install it on x86 NAS with ssh, or you can install it on a PC or Mac and map the NAS data volume to a network drive. The latter is simpler of course.
- vrspectreSep 01, 2016Apprentice
Crash plan looks interesting. My only hesitation is that I'm super lazy. I tend to prefer out of the box solutions that don't require me to instlal weird software. I can't really rely on installing it on a desktop so I'd have to install it on the NAS directly. I'm sure it's not supper difficult, but still not out of the box and so nobody will want to fix it if it's not working. where as if i keep everythign with netgear, they're insentivized to get it all working since it's all their product. It is tempting though.
- ReadyNAS-VaultSep 01, 2016Apprentice
vrspectre: we meant to post this earlier, but somehow must have made an error in uploading.
In response to your comparison of ReadyNAS Vault and Amazon's Cloud Drive sync option...
1. These aren't exactly apples to apples solutions, though both can be used for many similar purposes. One key difference you've already highlighted in this thread is that data is encrypted at rest with RNV. Meaning, the files are all encrypted on your device and never decrypted until they are returned to an authenticated device. Additionally, you have the option of using Personal Keys that the RNV service does not have access to (warning: if you use this option and lose/forget your passphrase, RNV cannot help you recover your data). There are several other features/function (e.g. granular control over backup rules, versioning/archiving, appropriate handling of attached devices, etc...) but those may not even matter for this case.
2. We hear you loud and clear on the price. Amazon's one price fits all seems designed to attract many users with the knowledge that some users (like those with 2 TB of data) will be "loss leaders." RNV has a variety of different plans that are built to cater to specific needs - perhaps one of our Personal plans will work. Or maybe our sales team can provide a discount - please check in at support@vault.readynas.com and reference this thread. The team will try to find the most economical plan for your use case and may be able to save you money.Hope this helps in the evaluation process.
- cathcamSep 06, 2016Guide
I wrote via email, and got pretty much a stock answer. Here is why ReadyNAS Vault doesn't work for me...
Really all I wanted was to backup my NAS. It’s still supported based on the web page, but the pricing is totally unrealistic. Most of the data is archive data, and won’t be accessed unless I have a total failure of the ReadyNAS.
It’s already just under 3Tb, and your plan is $39.95 per month for 2Tb. That’s totally unaffordable for a home user looking for occasional disaster recovery access and little else. Also your restrictions make it unsuable, I have backups of laptop hard drives going back to the early 1990’s archived on the ReadyNAS. The backups are often single files, many of them are over 15Gb in size. Again, chances are I’ll never need to access them. They are archived on the NAS and I just want the NAS backed up…I need none of the things you list as “features” – link sharing, folder sharing, multiple devices, nor do I need a mobile app.
- StephenBSep 02, 2016Guru - Experienced User
vrspectre wrote:
I'm sure it's not super difficult, but still not out of the box and so nobody will want to fix it if it's not working.
That is true- CrashPlan doesn't support headless installations on linux (though they have provided me support overall, they didn't support the installation itself). Like all NAS installs you have to pay attention to OS partition usage.
And I've seen one post here saying that the headless installations might become impossible in a future release.
I've been using it on my Pro-6 since 2012, and overall its worked out ok. There were bumps in the road in last summer (you'll find some posts from me and others on that in the forum).
I'm not ready to trust any Cloud Backup as my only backup, but for ~$60/year I'll gladly take it as disaster insurance.
- cathcamSep 02, 2016Guide
As others have posted, crashplan not supported in headless mode. Interestingly they do not support using Windows as a client using mapped drives to backup a NAS. Although they provide an unsupported workaround by installing ONLY in user mode, when the crashplan service is not installed.
http://support.code42.com/CrashPlan/4/Backup/Backing_Up_A_Windows_Network_Drive
Support is always a nebulous thing, and often a moving target. You think you are supported, until support tells you, you are not. You warranty and spport have expired, but you get great "support" through a community forum. Thanks guys!- StephenBSep 04, 2016Guru - Experienced User
This is true, though I have used crashplan support with good results several times over the years even though I use headless mode. They won't help with the install itself (though I wasn't needing that). But they did work to resolve my problems without fuss. Of course their business model is different from Netgear's (they get an ongoing revenue stream from their customers).
http://support.code42.com/CrashPlan/4/Backup/Backing_Up_A_Windows_Network_DriveIt is a bit odd - and perhaps there are historical reasons - they do support this mode in OSX. With older versions of Windows it is a bit harder to do.
Though if I ever need to reinstall crashplan, I likely will switch to this mode.
