mbielaw
Aug 05, 2015Tutor
file sharing outside of home network with owncloud
Hi all, I've spent half the day trying to figure this out, so please be kind. I have a ReadyNAS Ultra 4+ with 4.2.27 firmware running PHP 5.something and ownCloud 8.1, both from Whocares. My...
JennC
Aug 06, 2015NETGEAR Employee Retired
Hello mbielaw,
Welcome to the community!
ReadyCloud has its own permissions for shares, this can be used with ReadyNAS OS6 and not available on ReadyNAS OS4 and OS5.
What you can use with these legacy ReadyNAS devices is ReadyNAS Remote. However, ReadyNAS Remote is currently not compatible with Windows 10.
See ReadyNAs Remote FAQ and ReadyNAS Remote Setup
Hope this helps!
mbielaw
Aug 06, 2015Tutor
Hi Jenn,
Thanks for the reply.
I understand that ReadyCloud is not an option for my hardware (although I have seen that some have updated their old hardware to OS6).
I don't really want to use ReadyNAS Remote for my purposes because [unfortunately] it complicates file sharing with less tech-savvy people. I'd like to be able to share through a web browser. I believe ownCloud is a possible solution, but I'm stuck on the next step. Hopefully, there is someone in the community who uses ownCloud and can point me in the right direction.
Mark
- JennCAug 06, 2015NETGEAR Employee Retired
Hello mbielaw,
Thanks for clearing that out.
You may also try using http/s on the shares. Simply create user account for remote accessing the shares via http/s under Security > User & Group Accounts then create a share that you want to be accessible from on the Internet via web browser, configure the HTTP/S under Share listing of the share you created.
Below I have encircled media share (default share) as an example then click the http/s icon.
You will get options Read-only and read-write for default access, this is for the default permission of the share when accessing it remotely. Mark the enable webDav support and enter the user accounts that you want to use when accessing the share remotely.
Then enable Login authentication on this share. If you have other LAN device that uses port 443, enter a custom port number in the port 2 field. Then you have to forward port 443 to the LAN IP address of the NAS and that forwarding configuration on the router should have a port translation setting where you will enter the custom port you entered in the port 2 field.
To remotely access via web browser, the format should be https://<wanip_of_the_network_of_the_NAS>/shares or https://<wanip_of_the_network_of_the_NAS>/<share_name. Ex. https://119.11.11.11/shares or https://119.11.11.11/testshare. This should ask for login and will log you in or not depending on the permission you have set for the share.
I hope this helps.
- SandsharkAug 10, 2015Sensei
Chances are, you have a dynamic IP address. That being the case, you need a dynamic IP redirector that keeps track (via a program you run in your router, on the NAS, or on another computer on the home network that's always on) and links a URL to that changing IP address. Chances are that Port 80 and 443 are also blocked, which are the standard HTTP and HTTPS ports. So you will need to use an alternate port. The redirector service can help with HTTP alternate port re-direction, but not HTTPS, as re-directng HTTPS would circumvent the security it provides.
There are many such services with optionas that are both free and not, depending on your needs. I personally use No-IP.com. DynDNS is also popular (and the only one most Netgear routers support natively). But there are plenty more. I have two web sites runnig on my NAS, not OwnCloud, but it's the same principal. And I also run DDClient on the NAS to keep my IP up to date with No-IP.
So, as you can see, ReadyNAS Remote (or ReadyCloud for ReadyOS 6) starts to look a whole lot simpler for the novice than other options.
- StephenBAug 11, 2015Guru - Experienced User
Yes, it is simpler. Still, I don't think the features are all there, and the performance remains hit-or-miss.
OpenVPN in the Netgear routers isn't that difficult to set up though, and I like the idea of using my router as the only forwarding device. Main issue is that they need to support TUN for mobile devices.
- mbielawAug 16, 2015Tutor
Thank you to all for your suggestions. I need to find some time to try them out as I admittedly am a newbie and need a lot of time and reading to make these things work the first time through (and troubleshoot when they don't work!).
