mbielaw
Aug 06, 2015Tutor
file sharing outside of home network with owncloud
Hi all, I've spent half the day trying to figure this out, so please be kind. I have a ReadyNAS Ultra 4+ with 4.2.27 firmware running PHP 5.something and ownCloud 8.1, both from Whocares. My...
Aug 11, 2015Guru - Experienced User
Sandshark wrote:
So, as you can see, ReadyNAS Remote (or ReadyCloud for ReadyOS 6) starts to look a whole lot simpler for the novice than other options.
Yes, it is simpler. Still, I don't think the features are all there, and the performance remains hit-or-miss.
OpenVPN in the Netgear routers isn't that difficult to set up though, and I like the idea of using my router as the only forwarding device. Main issue is that they need to support TUN for mobile devices.
mbielaw
Aug 16, 2015Tutor
Thank you to all for your suggestions. I need to find some time to try them out as I admittedly am a newbie and need a lot of time and reading to make these things work the first time through (and troubleshoot when they don't work!).
