pst
Apr 16, 2014Tutor
fix for transmission not starting on 6.1.6/7
For what it's worth, Transmission hasn't been starting properly at system boot since 6.1.4 for me (ReadyNAS Pro).
I finally tracked it down.
in /etc/systemd/system/multi-user.target/wants/fvapp-transmissionr6.service there is a line:
After=apache2.service
change that to
After=readynasd.service
For some reason, transmission, which normally does not communicate at all with readynasd, in our version, does. The error message was:
SYSLOG_IDENTIFIER=transmission
MESSAGE=Error connecting to readynasd -2
and
MESSAGE=Error processing nml request
change that to
and
- super_poussinVirtuosotransmission discuss with rn_nml to check shares
I will modify the script to handle this change - super_poussinVirtuosoA new version is in the dropbox
big thanks to pst for pointing me a solution - Fantastic, much appreciated.
- Can confirm this starts correctly at boot, THANKS!
- xeltrosApprentice@poussin can you send your dropbox address ? it used to be in your signature but I don't see it there anymore. Only two links pointing out that you live in the same French department as my mother ;)
- super_poussinVirtuosoI'm on my phone Go in addons section for OS6 and in post available addons
- btaroliProdigyYou're looking for the post here: viewtopic.php?f=153&t=70914
After installing 3.00.6 I notice that the after value is "apache2.service readynasd.service" :)
haven't tried a restart yet, but others already report success. Thanks pst and super-poussin! - luk_slackwalkerAspirantThe fix worked installing transmission 3.0.0.6 from super-poussin dropbox.
Tried the same workaround with amule but no results; the service is running but the system doesn't list it as active.
Thanks a lot to pst and super-poussin!!!!!
Greets
Luca - PeterKocicAspirantHow does one install this dropbox version? Is there an easy way or guide?
