scrjs
Feb 07, 2021Apprentice
freshclam AV stops updating on my ReadyNAS
For some reason that I have not figured out on my ReadyNAS 314 ClamAV stops automatically updating. If I reboot the ReadyNAS it will update for a few days then stop updating If I ssh to root and...
Feb 08, 2021Guru - Experienced User
There's a much longer thread on this here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Antivirus-scanner-definition-file-update-failed/td-p/1943198
If you have ssh enabled, you could try manually editing /etc/freshclam.conf as described here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Antivirus-scanner-definition-file-update-failed/m-p/2051207#M190436 It'd be useful to know if it solves the problem.
scrjs
Feb 08, 2021Apprentice
Hi StephenB
Thanks for the tip!
I have implemented your suggestion
"If you have ssh enabled, you could try manually editing /etc/freshclam.conf as described here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Antivirus-scanner-definition-file-update-failed/m-p/2051207#M190436 It'd be useful to know if it solves the problem."
TestDatabases=false is set in my /etc/freshclam.conf.
I ran freshclam -v after setting the above and it ran successfully as noted below
I have rebooted the ReadyNAS and will now monitor if the change resolves the problem
- scrjsFeb 10, 2021Apprentice
StephenB, The AV has updated twice since TestDatabases=false is set in my /etc/freshclam.conf.
So far so good...
- StephenBFeb 11, 2021Guru - Experienced User
Good to hear. Hopefully it will continue to work ok.
- scrjsFeb 15, 2021Apprentice
Hi StephenB
I checked again today (Feb 16) and the AV has not updated fince Feb 11 so sadly the change TestDatabases=false setting in my /etc/freshclam.conf has failed to rectify or workaround the issue as seen in the log below
I ran freshclam -v which ran successfully and my AV updated to 59.26081 from 59.26076 though there are some interesting messages highlighted below
Freshclam seems to have disabled the AV and did not re-enable it. This has not happened in the past. Any thoughts?
I manually enabled AV successfully as noted belowNow back to the successful running of Freshclam. These details are noted below. Nothing unusual execpt for the warning in red text at the end.
ClamAV update process started at Tue Feb 16 11:18:32 2021
Using IPv6 aware code
Querying current.cvd.clamav.net
TTL: 1349
Software version from DNS: 0.103.1
main.cvd version from DNS: 59
main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr)
daily.cvd version from DNS: 26081
Retrieving http://database.clamav.net/daily-26077.cdiff
Trying to download http://database.clamav.net/daily-26077.cdiff (IP: 104.16.219.84)
Downloading daily-26077.cdiff [100%]
cdiff_apply: Parsed 10182 lines and executed 10182 commands
Retrieving http://database.clamav.net/daily-26078.cdiff
Trying to download http://database.clamav.net/daily-26078.cdiff (IP: 104.16.219.84)
Downloading daily-26078.cdiff [100%]
cdiff_apply: Parsed 11731 lines and executed 11731 commands
Retrieving http://database.clamav.net/daily-26079.cdiff
Trying to download http://database.clamav.net/daily-26079.cdiff (IP: 104.16.219.84)
Downloading daily-26079.cdiff [100%]
cdiff_apply: Parsed 11600 lines and executed 11600 commands
Retrieving http://database.clamav.net/daily-26080.cdiff
Trying to download http://database.clamav.net/daily-26080.cdiff (IP: 104.16.219.84)
Downloading daily-26080.cdiff [100%]
cdiff_apply: Parsed 10313 lines and executed 10313 commands
Retrieving http://database.clamav.net/daily-26081.cdiff
Trying to download http://database.clamav.net/daily-26081.cdiff (IP: 104.16.219.84)
Downloading daily-26081.cdiff [100%]
cdiff_apply: Parsed 10297 lines and executed 10297 commands
Loading signatures from daily.cld
Properly loaded 4010384 signatures from new daily.cld
daily.cld updated (version: 26081, sigs: 4051203, f-level: 63, builder: raynman)
Querying daily.26081.93.1.0.6810DB54.ping.clamav.net
Can't query daily.26081.93.1.0.6810DB54.ping.clamav.net
bytecode.cvd version from DNS: 331
bytecode.cld is up to date (version: 331, sigs: 94, f-level: 63, builder: anvilleg)
Database updated (8616199 signatures) from database.clamav.net (IP: 104.16.219.84)
WARNING: Clamd was NOT notified: Can't connect to clamd through /var/run/clamav/clamd.ctl: No such file or directoryI have searched the file system and indeed clamd.ctl does not exist anywhere on the file system.
Any thoughts on the missing clamd.ctl?
Cheers Rob
