scrjs
Feb 07, 2021Apprentice
freshclam AV stops updating on my ReadyNAS
For some reason that I have not figured out on my ReadyNAS 314 ClamAV stops automatically updating. If I reboot the ReadyNAS it will update for a few days then stop updating If I ssh to root and...
scrjs
Feb 15, 2021Apprentice
Just FYI re WARNING: Clamd was NOT notified: Can't connect to clamd through /var/run/clamav/clamd.ctl: No such file or directory
Subsequent to the update (quoted below) I have discovered that "/var/run/clamav/clamd.ctl" was created after I enabled AV so I suspect this isnot a contributer to the AV not updating.
Freshclam when run from root in an SSH session sems to update AV however the AV seems to stop updating after a period of time.
scrjs wrote:Hi StephenB
I checked again today (Feb 16) and the AV has not updated fince Feb 11 so sadly the change TestDatabases=false setting in my /etc/freshclam.conf has failed to rectify or workaround the issue as seen in the log below
I ran freshclam -v which ran successfully and my AV updated to 59.26081 from 59.26076 though there are some interesting messages highlighted below
Freshclam seems to have disabled the AV and did not re-enable it. This has not happened in the past. Any thoughts?
I manually enabled AV successfully as noted belowNow back to the successful running of Freshclam. These details are noted below. Nothing unusual execpt for the warning in red text at the end.
ClamAV update process started at Tue Feb 16 11:18:32 2021
Using IPv6 aware code
Querying current.cvd.clamav.net
TTL: 1349
Software version from DNS: 0.103.1
main.cvd version from DNS: 59
main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr)
daily.cvd version from DNS: 26081
Retrieving http://database.clamav.net/daily-26077.cdiff
Trying to download http://database.clamav.net/daily-26077.cdiff (IP: 104.16.219.84)
Downloading daily-26077.cdiff [100%]
cdiff_apply: Parsed 10182 lines and executed 10182 commands
Retrieving http://database.clamav.net/daily-26078.cdiff
Trying to download http://database.clamav.net/daily-26078.cdiff (IP: 104.16.219.84)
Downloading daily-26078.cdiff [100%]
cdiff_apply: Parsed 11731 lines and executed 11731 commands
Retrieving http://database.clamav.net/daily-26079.cdiff
Trying to download http://database.clamav.net/daily-26079.cdiff (IP: 104.16.219.84)
Downloading daily-26079.cdiff [100%]
cdiff_apply: Parsed 11600 lines and executed 11600 commands
Retrieving http://database.clamav.net/daily-26080.cdiff
Trying to download http://database.clamav.net/daily-26080.cdiff (IP: 104.16.219.84)
Downloading daily-26080.cdiff [100%]
cdiff_apply: Parsed 10313 lines and executed 10313 commands
Retrieving http://database.clamav.net/daily-26081.cdiff
Trying to download http://database.clamav.net/daily-26081.cdiff (IP: 104.16.219.84)
Downloading daily-26081.cdiff [100%]
cdiff_apply: Parsed 10297 lines and executed 10297 commands
Loading signatures from daily.cld
Properly loaded 4010384 signatures from new daily.cld
daily.cld updated (version: 26081, sigs: 4051203, f-level: 63, builder: raynman)
Querying daily.26081.93.1.0.6810DB54.ping.clamav.net
Can't query daily.26081.93.1.0.6810DB54.ping.clamav.net
bytecode.cvd version from DNS: 331
bytecode.cld is up to date (version: 331, sigs: 94, f-level: 63, builder: anvilleg)
Database updated (8616199 signatures) from database.clamav.net (IP: 104.16.219.84)
WARNING: Clamd was NOT notified: Can't connect to clamd through /var/run/clamav/clamd.ctl: No such file or directoryI have searched the file system and indeed clamd.ctl does not exist anywhere on the file system.
Any thoughts on the missing clamd.ctl?
Cheers Rob
TTL: 1349
Cheers Rob
Feb 16, 2021Guru - Experienced User
My understanding from other forums is that clamd.ctl should be created when the service is started, so that's consistent with your experience.
Any thoughts on how long it takes for AV to stop updating? Are you getting a notice that the update is failing? If not, has the service crashed?
- scrjsFeb 16, 2021Apprentice
Hi StephenB
Thanks again
"Any thoughts on how long it takes for AV to stop updating?"
In this case it updated twice then stopped.
"Are you getting a notice that the update is failing?"
No I am not getting any notification. Wish I was - any ideas?
"If not, has the service crashed?"
I did not check and your correct I should have done that. When I login to the UI it shows as enabled for what that is worth.
I presume I look for a clamavd running? Can you confirm what I should look for?
Futher to my previous update
Thanks again
I know what to look for to see if ClamAV is running. I just checked and it is running at the moment
root 3370 1 91 11:59 ? 09:39:25 /usr/sbin/clamd --foreground=true --config-file=/etc/clamav/clamd.conf
- StephenBFeb 16, 2021Guru - Experienced User
scrjs wrote:Can you confirm what I should look for?
I'd start by checking the status of the services and timer
# systemctl status clamav-freshclam.service # systemctl status clamav-freshclam.timer # systemctl status clamav-daemon.service
The clamav-freshclam service is normally inactive (it is triggered by the timer). But you should still see status from the last time it ran.
hi StephenB
Thanks so much for the advise
The output from these commands which I ran a few moments ago look as expected "I think" for a correctly running ClamAV. Can you confirm?
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Tue 2021-02-16 12:15:29 AEDT; 19h ago Process: 4507 ExecStart=/usr/bin/freshclam --quiet (code=exited, status=1/FAILURE) Main PID: 4507 (code=exited, status=1/FAILURE) Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.timer ● clamav-freshclam.timer - Anti-Virus Definition Update Timer Loaded: loaded (/lib/systemd/system/clamav-freshclam.timer; static; vendor preset: disabled) Active: active (waiting) since Tue 2021-02-16 11:58:34 AEDT; 19h ago Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. root@xxxxxReadyNAS:~# systemctl status clamav-daemon.service ● clamav-daemon.service - Clam AntiVirus userspace daemon Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: disabled) Active: active (running) since Tue 2021-02-16 11:59:00 AEDT; 19h ago Main PID: 3370 (clamd) CGroup: /system.slice/clamav-daemon.service └─3370 /usr/sbin/clamd --foreground=true --config-file=/etc/clamav/clamd.conf Feb 17 06:41:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 06:41:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 06:51:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 06:51:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:01:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:01:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:11:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:11:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:21:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:21:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. - scrjsFeb 16, 2021Apprentice
Hi StephenB
I have been looking into the commands you gave in update
scrjs wrote:hi StephenB
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Tue 2021-02-16 12:15:29 AEDT; 19h ago Process: 4507 ExecStart=/usr/bin/freshclam --quiet (code=exited, status=1/FAILURE) Main PID: 4507 (code=exited, status=1/FAILURE) Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.timer ● clamav-freshclam.timer - Anti-Virus Definition Update Timer Loaded: loaded (/lib/systemd/system/clamav-freshclam.timer; static; vendor preset: disabled) Active: active (waiting) since Tue 2021-02-16 11:58:34 AEDT; 19h ago Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. root@xxxxxReadyNAS:~# systemctl status clamav-daemon.service ● clamav-daemon.service - Clam AntiVirus userspace daemon Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: disabled) Active: active (running) since Tue 2021-02-16 11:59:00 AEDT; 19h ago Main PID: 3370 (clamd) CGroup: /system.slice/clamav-daemon.service └─3370 /usr/sbin/clamd --foreground=true --config-file=/etc/clamav/clamd.conf Feb 17 06:41:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 06:41:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 06:51:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 06:51:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:01:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:01:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:11:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:11:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:21:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK. Feb 17 07:21:10 xxxxxReadyNAS clamd[3370]: SelfCheck: Database status OK.I disabled ClamAV and re-enable it and this time see
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: inactive (dead) root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.timer ● clamav-freshclam.timer - Anti-Virus Definition Update Timer Loaded: loaded (/lib/systemd/system/clamav-freshclam.timer; static; vendor preset: disabled) Active: active (waiting) since Wed 2021-02-17 10:01:25 AEDT; 35s ago Feb 17 10:01:25 xxxxxReadyNAS systemd[1]: Started Anti-Virus Definition Update Timer. root@xxxxxReadyNAS:~# systemctl status clamav-daemon.service ● clamav-daemon.service - Clam AntiVirus userspace daemon Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: disabled) Active: active (running) since Wed 2021-02-17 10:01:25 AEDT; 59s ago Main PID: 4922 (clamd) CGroup: /system.slice/clamav-daemon.service └─4922 /usr/sbin/clamd --foreground=true --config-file=/etc/clamav/clamd.conf Feb 17 10:01:25 xxxxxReadyNAS systemd[1]: Started Clam AntiVirus userspace daemon. Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Received 0 file descriptor(s) from systemd. Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: clamd daemon 0.100.2 (OS: linux-gnu, ARCH: x86_64, CPU: x86_64) Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Running as user root (UID 0, GID 0) Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Log file size limited to 1048576 bytes. Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Reading databases from /var/lib/clamav Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Not loading PUA signatures. Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Only loading official signatures. Feb 17 10:01:26 xxxxxReadyNAS clamd[4922]: Bytecode: Security mode set to "TrustSigned".This looks more normal to me, however would appreciate your thoughts...
Interestingly when I first sent you output from # systemctl status clamav-freshclam.service we had a FAILURE repeated below.
compared to now
You stated "The clamav-freshclam service is normally inactive (it is triggered by the timer). But you should still see status from the last time it ran."
What should I expect? (sorry for my naivety linux is not my stength)
- StephenBFeb 17, 2021Guru - Experienced User
The second status looks correct to me.
It does look like the service had failed for some reason earlier, though there's not enough info to say why. I'm not sure if the log rotation would have given more clues or not.
- scrjsFeb 17, 2021Apprentice
Hi StephenB
Many thanks for the continued discussion below
StephenB wrote:The second status looks correct to me.
Which log was rotated? Is there another mechanism to get this information?
I will check
In a few days...
- StephenBFeb 18, 2021Guru - Experienced User
scrjs wrote: Which log was rotated? Is there another mechanism to get this information?Your first status includes
Systemd consolidates the logs, and that is what was rotated. There's no other mechanism.
- scrjsFeb 18, 2021Apprentice
Thanks for letting me know StephenB
I'll check again in a few days
- scrjsFeb 20, 2021Apprentice
I will check
In a few days...
Hi StephenB
I rebooted the ReadyNAS yesterday and just checked the status and noted the failure in
This service yesterday, after the reboot, showed
which looks correct. Checking just now (Feb 21) it shows
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Sat 2021-02-20 16:55:56 AEDT; 19h ago Main PID: 5129 (code=exited, status=1/FAILURE) Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Unfortunatly again no log info.
Ran freshclam -v with the following results and then checked clamav-freshclam.service with the following results with the service stilled in FAILED status
root@xxxxxReadyNAS:~# freshclam -v Current working dir is /var/lib/clamav Max retries == 5 ClamAV update process started at Sun Feb 21 12:29:49 2021 Using IPv6 aware code Querying current.cvd.clamav.net TTL: 1666 Software version from DNS: 0.103.1 main.cvd version from DNS: 59 main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr) daily.cvd version from DNS: 26086 Retrieving http://database.clamav.net/daily-26086.cdiff Trying to download http://database.clamav.net/daily-26086.cdiff (IP: 104.16.218.84) Downloading daily-26086.cdiff [100%] cdiff_apply: Parsed 4327 lines and executed 4327 commands Loading signatures from daily.cld Properly loaded 3982440 signatures from new daily.cld daily.cld updated (version: 26086, sigs: 4008487, f-level: 63, builder: raynman) Querying daily.26086.93.1.0.6810DA54.ping.clamav.net Can't query daily.26086.93.1.0.6810DA54.ping.clamav.net bytecode.cvd version from DNS: 332 bytecode.cld is up to date (version: 332, sigs: 93, f-level: 63, builder: awillia2) Database updated (8573482 signatures) from database.clamav.net (IP: 104.16.218.84) Clamd successfully notified about the update. root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Sat 2021-02-20 16:55:56 AEDT; 19h ago Main PID: 5129 (code=exited, status=1/FAILURE) Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Is any way to detail detail on what happened to "clamav-freshclam.service - ClamAV virus database updater" cause the failure "failed (Result: exit-code) since Sat 2021-02-20 16:55:56 AEDT" ?
- StephenBFeb 21, 2021Guru - Experienced User
Are you seeing any errors in system.log, kernel.log, system-journal.log around the time that that service failed?
- scrjsFeb 21, 2021Apprentice
StephenB wrote:Are you seeing any errors in system.log, kernel.log, system-journal.log around the time that that service failed?
Hi StephenB
Can you please let me know the path to these logs?
I can't find them...
Also just checked the commands and this time I have some log info before they rotated and see the following (time now is 17:58 on Feb 22) with a failue in ClamAV virus database updater
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Mon 2021-02-22 17:17:34 AEDT; 35min ago Main PID: 4077 (code=exited, status=1/FAILURE) Feb 22 17:17:34 xxxxxReadyNAS systemd[1]: Starting ClamAV virus database updater... Feb 22 17:17:34 xxxxxReadyNAS freshclam[4077]: ClamAV update process started at Mon Feb 22 17:17:34 2021 Feb 22 17:17:34 xxxxxReadyNAS freshclam[4077]: main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr) Feb 22 17:17:34 xxxxxReadyNAS freshclam[4077]: daily.cld is up to date (version: 26087, sigs: 4008904, f-level: 63, builder: raynman) Feb 22 17:17:34 xxxxxReadyNAS freshclam[4077]: bytecode.cld is up to date (version: 332, sigs: 93, f-level: 63, builder: awillia2) Feb 22 17:17:34 xxxxxReadyNAS systemd[1]: clamav-freshclam.service: Main process exited, code=exited, status=1/FAILURE Feb 22 17:17:34 xxxxxReadyNAS systemd[1]: Failed to start ClamAV virus database updater. Feb 22 17:17:34 xxxxxReadyNAS systemd[1]: clamav-freshclam.service: Unit entered failed state. Feb 22 17:17:34 xxxxxReadyNAS systemd[1]: clamav-freshclam.service: Failed with result 'exit-code'. root@xxxxxReadyNAS:~# systemctl status clamav-daemon.service ● clamav-daemon.service - Clam AntiVirus userspace daemon Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: disabled) Active: active (running) since Mon 2021-02-22 17:01:22 AEDT; 52min ago Main PID: 3329 (clamd) CGroup: /system.slice/clamav-daemon.service └─3329 /usr/sbin/clamd --foreground=true --config-file=/etc/clamav/clamd.conf Feb 22 17:13:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:13:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:23:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:23:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:33:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:33:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:43:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:43:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:53:05 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:53:05 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. root@xxxxxReadyNAS:~# systemctl status clamav-daemon.service ● clamav-daemon.service - Clam AntiVirus userspace daemon Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: disabled) Active: active (running) since Mon 2021-02-22 17:01:22 AEDT; 52min ago Main PID: 3329 (clamd) CGroup: /system.slice/clamav-daemon.service └─3329 /usr/sbin/clamd --foreground=true --config-file=/etc/clamav/clamd.conf Feb 22 17:13:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:13:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:23:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:23:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:33:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:33:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:43:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:43:04 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:53:05 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK. Feb 22 17:53:05 xxxxxReadyNAS clamd[3329]: SelfCheck: Database status OK.Ran freshclam -v and all appears up to date
root@xxxxxReadyNAS:~# freshclam -v Current working dir is /var/lib/clamav Max retries == 5 ClamAV update process started at Mon Feb 22 18:04:29 2021 Using IPv6 aware code Querying current.cvd.clamav.net TTL: 548 Software version from DNS: 0.103.1 main.cvd version from DNS: 59 main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr) daily.cvd version from DNS: 26087 daily.cld is up to date (version: 26087, sigs: 4008904, f-level: 63, builder: raynman) bytecode.cvd version from DNS: 332 bytecode.cld is up to date (version: 332, sigs: 93, f-level: 63, builder: awillia2)
Thoughts?
- StephenBFeb 22, 2021Guru - Experienced User
scrjs wrote:
Hi StephenB
Download the log zip file from the NAS web ui. These logs are extracted from the systemd journal when you download the zip - they don't exist in the OS partition.
You could also attempt to search the journal directly with journalctl, but there's a lot of stuff in there, so you'd want to filter the search. That could result in missing some errors.
scrjs wrote:
Hi StephenB
Thoughts?
If you manually start the service with systemctl start clamav-freshclam.service do you see the same failure?
- scrjsFeb 23, 2021Apprentice
Hi StephenB
I did a log update yesterday that seems to have been lost.
What I can confirm is that when the clamav-freshclam.service - ClamAV virus database updater is in a FAILED status, a systemctl start clamav-freshclam.service does in fact restart the service.
Since that start after it failed the services continues to run as noted below and updated my AV this morning successfully
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: inactive (dead) since Wed 2021-02-24 08:24:18 AEDT; 4h 51min ago Process: 5693 ExecStart=/usr/bin/freshclam --quiet (code=exited, status=0/SUCCESS) Main PID: 5693 (code=exited, status=0/SUCCESS) Feb 24 08:22:40 xxxxxReadyNAS systemd[1]: Starting ClamAV virus database updater... Feb 24 08:22:44 xxxxxReadyNAS freshclam[5693]: ClamAV update process started at Wed Feb 24 08:22:44 2021 Feb 24 08:22:44 xxxxxReadyNAS freshclam[5693]: main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr) Feb 24 08:22:46 xxxxxReadyNAS freshclam[5693]: Downloading daily-26089.cdiff [100%] Feb 24 08:24:03 xxxxxReadyNAS freshclam[5693]: daily.cld updated (version: 26089, sigs: 4000162, f-level: 63, builder: raynman) Feb 24 08:24:09 xxxxxReadyNAS freshclam[5693]: Can't query daily.26089.93.1.0.6810DA54.ping.clamav.net Feb 24 08:24:09 xxxxxReadyNAS freshclam[5693]: bytecode.cld is up to date (version: 332, sigs: 93, f-level: 63, builder: awillia2) Feb 24 08:24:17 xxxxxReadyNAS freshclam[5693]: Database updated (8565157 signatures) from database.clamav.net (IP: 104.16.218.84) Feb 24 08:24:17 xxxxxReadyNAS freshclam[5693]: Clamd successfully notified about the update. Feb 24 08:24:18 xxxxxReadyNAS systemd[1]: Started ClamAV virus database updater.
Netgear are asking for logs, however we have always seens that this failure occurs without any notification so log collection before rotation is difficult.
Thoughts...
- StephenBFeb 24, 2021Guru - Experienced User
Thoughts...
They are apparently actively working on a hot fix, so perhaps you should just restart the service manually if you see it fails again.
How quickly are your logs rotating? (journalctl will tell you the oldest log entry, since by default it lists the oldest first).
- scrjsFeb 24, 2021Apprentice
Hi StephenB
StephenB wrote:
scrjs wrote:Netgear are asking for logs, however we have always seens that this failure occurs without any notification so log collection before rotation is difficult.
Thoughts...
Yes I was aware Netgear are working on a Hotfix so you suggestion makes sense.
I just ran journalctl and currently it suggests
-- Logs begin at Mon 2021-02-22 21:30:50 AEDT, end at Wed 2021-02-24 22:13:22 AEDT. --
The begin date is just after a boot of the NAS so they have not yet rotated.
Just checked systemctl status clamav-freshclam.service which continues to run as noted below
I hope the hotfix will be available soon...
scrjs wrote:
Hi StephenB
The journal doesn't start fresh when the NAS reboots. 2 days isn't much retention, my main NAS goes back about a month.
Have you enabled the audit service? Just wondering what is generating so many log entries.
Hi StephenB
I have NOT enabled the Audit Service. What can I check?
scrjs wrote: I have NOT enabled the Audit Service. What can I check?Maybe just scroll through a few screens worth of journalctl entries, and see if anything seems to be flooding the logs.
FWIW, I generally see about ~700 log entries per day. But of course this will vary, depending on how your NAS is configured and how it is used. So the low retention doesn't necessarily mean anything is wrong - it just seems to me that your system is doing a lot of logging.
You can count the number of entries for a specific day:
root@NAS:~# journalctl --no-pager | grep "Feb 19" | wc 701 8685 61460The first entry is the number of lines that go through the grep filter - so there were 701 entries in my main NAS dated Feb 19.
You can also count them for a specific hour by simply changing the filter a bit.
root@NAS:~# journalctl --no-pager | grep "Feb 19 23:" | wc 34 419 3132So my system logged 34 entries between Feb 19 23:00:00 and Feb 19 23:59:59
Hi StephenB
Thanks for the education! I am not proficient with Unix OS
In my case I am logging a bit more then you +300 per day and +20 per hour
root@xxxxxReadyNAS:~# journalctl --no-pager | grep "Feb 23" | wc 1085 11442 94861 root@xxxxxReadyNAS:~# journalctl --no-pager | grep "Feb 23 10:" | wc 51 530 4505Looks like my Windows FileHistory is creating the extra entries for some Apple MobileSync. Not critical but extra logging
Feb 22 21:30:50 xxxxxReadyNAS tracker-miner-fs[2731]: (tracker-miner-fs:2731): Tracker-CRITICAL **: (Sparql buffer) Error in task 2 (file:///data/Backup/FileHist-T590/scrjs/xxxxxxxxxx-T590/Data/C/Users/scrjs/Apple/MobileSync/Backup/097 38580e54d9155c885c64d0eb6853c06fdaaf6/06/06b60848b6afef08d879bf24afe5855bb7fd0d44%20(2020_08_12%2001_26_35%20UTC)) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url (strerror of errno (not necessarily related): Reso urce temporarily unavailable) Feb 22 21:30:50 xxxxxReadyNAS tracker-miner-fs[2731]: (tracker-miner-fs:2731): Tracker-CRITICAL **: Could not execute sparql: UNIQUE constraint failed: nie:DataObject.nie:url (strerror of errno (not necessarily related): Resource tempo rarily unavailable)
Thanks again for the tip!
- scrjsMar 01, 2021Apprentice
Hi StephenB
FWIW AV My NAS has been updaing AV successfully for 7 days after the restart after failure command systemctl start clamav-freshclam.service
root@xxxxxReadyNAS:~# systemctl status clamav-freshclam.service ● clamav-freshclam.service - ClamAV virus database updater Loaded: loaded (/lib/systemd/system/clamav-freshclam.service; static; vendor preset: disabled) Active: inactive (dead) since Tue 2021-03-02 08:31:18 AEDT; 6h ago Process: 12506 ExecStart=/usr/bin/freshclam --quiet (code=exited, status=0/SUCCESS) Main PID: 12506 (code=exited, status=0/SUCCESS) Mar 02 08:27:34 xxxxxReadyNAS systemd[1]: Starting ClamAV virus database updater... Mar 02 08:27:35 xxxxxReadyNAS freshclam[12506]: ClamAV update process started at Tue Mar 2 08:27:35 2021 Mar 02 08:27:36 xxxxxReadyNAS freshclam[12506]: main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr) Mar 02 08:27:40 xxxxxReadyNAS freshclam[12506]: Downloading daily-26095.cdiff [100%] Mar 02 08:30:36 xxxxxReadyNAS freshclam[12506]: daily.cld updated (version: 26095, sigs: 3956535, f-level: 63, builder: raynman) Mar 02 08:30:43 xxxxxReadyNAS freshclam[12506]: Can't query daily.26095.93.1.0.6810DB54.ping.clamav.net Mar 02 08:30:43 xxxxxReadyNAS freshclam[12506]: bytecode.cld is up to date (version: 332, sigs: 93, f-level: 63, builder: awillia2) Mar 02 08:31:14 xxxxxReadyNAS freshclam[12506]: Database updated (8521530 signatures) from database.clamav.net (IP: 104.16.219.84) Mar 02 08:31:15 xxxxxReadyNAS freshclam[12506]: Clamd successfully notified about the update. Mar 02 08:31:18 xxxxxReadyNAS systemd[1]: Started ClamAV virus database updater.
- StephenBMar 02, 2021Guru - Experienced User
scrjs wrote:FWIW AV My NAS has been updaing AV successfully for 7 days after the restart after failure command systemctl start clamav-freshclam.service
Thx for updating us. Netgear says they are still working on the hotfix (no idea why it's taken that long).
- scrjsMar 04, 2021Apprentice
Hi StephenB
The hotfix automatically applied to my ReadyNAS as noted in the Logs presented in the User Interface where I now see (in timezone AEDT)
Mar 04, 2021 05:08:47 PM System: A hotfix was applied to your system (6.10.4 Hotfix 1). Prior to the application of the Hotfix my AV was updating as indicated in my revious update
