mdgm-ntgr
Oct 12, 2013NETGEAR Employee Retired
General discussion on LMS for OS6
Please discuss LMS for OS6 here. Continues from http://www.readynas.com/forum/viewtopic.php?f=155&t=70937
rjwerth1
Dec 09, 2015Aspirant
This no longer seems to work with 6.4.1. I get "Cannot install...." errors when I upload LMS.
UPDATE: Well, it seems to be working now. If you follow the instructions above, you will get "Cannot install" errors, but strangely enough, it seems to do it anyway. I had to go through the process a couple of times, but at last, I have LMS 7.9 and ReadyNAS App 1.08.
lpgravelle
I must be doing something wrong.
I install lms 1.0.6 from app page.
I try to install 7.8.0 - get error message can't install.
repeat a few times, no success.
I then try to upgrade to 1.0.8. still same error message. try a few times - no success. All it manages to do is uninstall 1.0.6.
Did you hard/soft reset between installs? Any other hints?
