mdgm-ntgr
Oct 12, 2013NETGEAR Employee Retired
General discussion on LMS for OS6
Please discuss LMS for OS6 here. Continues from http://www.readynas.com/forum/viewtopic.php?f=155&t=70937
F_L_
Nov 03, 2013Tutor
Another question.
Whats the best way to start over from scratch?
I had 7.7.3 installed but since I had some issues with it I tried to remove it. Removal failed though.
(But it was removed from the APP page)
So I tried to install 7.7.2 and it failed too.
The LMS package is also failing so it seems that I am stuck.
Rebooted the NAS and that didnt help.
EDIT: Now 7.7.2 magically appeared under APPS, so far so good.
But I still have the issue with not all plugins available.
Seems to be a cache issue:
http://forums.slimdevices.com/showthrea ... tings-page
Clearing /var/lib/squeezeboxserver/cache# didnt help
EDIT2: If you disable Extension Downloader plugin all 3rd party plugins disappears. Enable it to have them visible again
