mdgm-ntgr
Oct 12, 2013NETGEAR Employee Retired
General discussion on LMS for OS6
Please discuss LMS for OS6 here. Continues from http://www.readynas.com/forum/viewtopic.php?f=155&t=70937
nsne
Jun 21, 2015Virtuoso
So, I managed to get the UE Media Server running on my 314, then I decided I didn't like it and "downgraded" (read: "re-upgraded") everything to Squeezebox/LMS. UE (10+) was stagnant, whereas LMS (7.x) still feels active and fresh.
I installed the LMS 1.0.6 add-on from the "Available Apps" and the latest 7.9 nightly. It's working fine, although I am noticing some UI sluggishness from the ReadyNAS.
I noticed that S-P's Dropbox has lms_1.0.8_all.deb, which seems to be newer than the ReadyNAS add-on and also designed for 7.8+ of the LMS nightlies. Can I just manually install this over 1.0.6, or is there some sort of uninstall process or radical change I should be aware of?
