mdgm-ntgr
Oct 12, 2013NETGEAR Employee Retired
General discussion on LMS for OS6
Please discuss LMS for OS6 here. Continues from http://www.readynas.com/forum/viewtopic.php?f=155&t=70937
nsne
Jun 22, 2015Virtuoso
Never mind. I answered my own question.
Here's a step-by-step for anyone who wants to install the latest and greatest LMS on their OS 6 ReadyNAS:
1. Install S-P's Logitech Media Server 1.0.6 add-on from the ReadyNAS add-on directory.
2. Install the LMS of your choice (e.g., 7.7, 7.8, 7.9) from the nightly pages by manually uploading the .deb file.
3. Install the lms_1.0.8_all.deb from S-P's Dropbox to bring the LMS app to the current version.
This is working brilliantly for me, even with multiple plugins enabled. LMS is speedy, and the lag is gone from the ReadyNAS admin GUI. Can't even fathom why I upgraded to UE.
- rjwerth1Dec 09, 2015Aspirant
This no longer seems to work with 6.4.1. I get "Cannot install...." errors when I upload LMS.
UPDATE: Well, it seems to be working now. If you follow the instructions above, you will get "Cannot install" errors, but strangely enough, it seems to do it anyway. I had to go through the process a couple of times, but at last, I have LMS 7.9 and ReadyNAS App 1.08.
- lpgravelleDec 09, 2015Aspirant
I must be doing something wrong.
I install lms 1.0.6 from app page.
I try to install 7.8.0 - get error message can't install.
repeat a few times, no success.
I then try to upgrade to 1.0.8. still same error message. try a few times - no success. All it manages to do is uninstall 1.0.6.
Did you hard/soft reset between installs? Any other hints?
- rjwerthFeb 15, 2016Luminary
Hey everyone. Has anyone managed to do this on 6.4.2? When I upgraded, it borked LMS and now, I can't get the later versions working anymore.
- lpgravelleFeb 15, 2016Aspirant
Nope. Nothing works for me. I have to rely on the LMS running on my computer.
