mdgm-ntgr
Oct 12, 2013NETGEAR Employee Retired
General discussion on LMS for OS6
Please discuss LMS for OS6 here. Continues from http://www.readynas.com/forum/viewtopic.php?f=155&t=70937
- F_L_TutorSweet!
Many thanks!
To upgrade you only need to run the 7.8 deb right?
Or is LMS still needed? - F_L_Tutor
F.L. wrote: Sweet!
Many thanks!
Ended up installing both files, got an installation failed message but LMS 7.8 is up and running anyway. - F_L_TutorAnyone tried to add the Google Music addon for LMS on the ReadyNas?
https://github.com/hechtus/squeezebox-googlemusic
EDIT: tried myself and got stuck at:
The following packages have unmet dependencies:
python-dev : Depends: python (= 2.7.3-4+deb7u1) but 2.7.3-4 is to be installed
Will try more later...
EDIT: apt-get install python2.7-dev did the trick. Seems to work fine now
EDIT2: be sure to use at least 3.1.1 of the unoffical google music api - JohnNultyApprenticeOK, couldn't resist - upgraded to 7.8 with S-P's files on the dropbox. Like F.L, initial message makes it appear that the first file didn't install, but after the LMS file installed, all is OK. Thanks again S-P :thumbsup:
- MickatroidAspirantHi Super Poussin, do you have plans to release new versions of LMS into the ReadyNAS Apps store? If not I will use your drop box files. Either way a (small admittedly) donation coming your way. When the LMS app arrived in the apps store I pretty much immediately upgraded my ReadyNAS duo. Merci beaucoup.
- super_poussinVirtuosoHello I will check if there's a new build and do it for OS6
App Store is no more used and I can't make addon for duo my unit is dead - MickatroidAspirantGreat to hear you are still interested in LMS and the ReadyNAS. Although it's a shame you are not using the Netgear apps 'store' anymore. You seem to have many good addons there.
I don't need LMS on my duo, in any case there is still a SPARC version in the nightly builds. The Duo was, with its CPU, soooo slow. My ReadyNAS 312 can build a full catalog around 100 times faster. Your Duo failed? I was starting to think mine was deathproof :) - MickatroidAspirantIt looks like 7.8.1 has been released: http://downloads.slimdevices.com/nightl ... hp?ver=7.8
Super-poussin, can you please say if the logitechmediaserver 7.8.1 all.deb package just be used in place of the 7.8.0 package in your dropbox?
M - AmudanAspirantHi super-poussin, thanks for your effort in providing the add-on for Ready NAS.
I recently bought Ready NAS RN104 ( OS 6.1.8 ). I am new to NAS and Linux. I have gone through most of the forum topics regarding Logitech media server(LMS) and tried to install it on my NAS.
My network has NAS connected to Wi-Fi router and Laptop. There is no internet connection. I used to run LMS on the laptop and play it on my Squeeze touch.
Now I want to run LMS on my NAS.
I tried to install LMS 7.8.0 files from your community drop box. As per the readme.txt, installed "logitechmediaserver_7.8.0_all.deb" waited for
installation success message and then installed "lms_1.0.7_all.deb"waited for installation success message. Now my app showed in the installed App screen.
Restarted the NAS. When I tried to switch on LMS, I am getting "Application Failed to initialize" 22002010000 message and app failed to launch.
Please help me. Is any thing i failed to do. - super_poussinVirtuoso
Amudan wrote: Hi super-poussin, thanks for your effort in providing the add-on for Ready NAS.
I try on my arm unit and it works fine , the only way to diagnose will be an ssh access to your nas if possible (PM me)
