jjmcmahon7
Apr 24, 2014Aspirant
HeadPhones for RN314 OS 6
I just got a ReadyNAS 314 with OS 6.1.7 on it and i attempted to load Headphones from the following site: https://rnxtras.com/addons/headphones-readynas-6-all I used these plugins previously on ...
MoonSire
Sep 03, 2014Aspirant
I just installed HeadPhones from rnxtras myself on my RN314 and it is showing the same symptoms. I uploaded the .deb through the web interface and when the application was successfully installed I started it by clicking the "ON" button. When trying to access the HeadPhones web interface I only get "The connection was reset" in Firefox.
I restarted both the apache2.service and the headphones.service, but there was no difference.
Checking the
but the launch button takes you to <server>:8282. I also have transmission running on port 8181 so I suspect this is a configuration issue with HeadPhones. I will try to find where the port can be changed...
I suspect that @WhoCares needs to update the package on rnxtras.com with a changed port.
root@nas:/apps/headphones# /etc/init.d/headphones status
headphones.service - LSB: starts instance of Headphones
Loaded: loaded (/etc/init.d/headphones)
Active: inactive (dead)
CGroup: name=systemd:/system/headphones.service
Checking the
/apps/headphones/config/logs/headphones.logshows this:
03-Sep-2014 12:37:43 - INFO :: MainThread : Checking to see if the database has all tables....
03-Sep-2014 12:37:47 - INFO :: MainThread : Retrieving latest version information from github
03-Sep-2014 12:37:47 - INFO :: MainThread : You are running an unknown version of Headphones. Run the updater to identify your version
03-Sep-2014 12:37:47 - INFO :: MainThread : Daemonized to PID: 32438
03-Sep-2014 12:37:47 - INFO :: MainThread : Writing PID 32438 to /var/run/headphones/headphones.pid
03-Sep-2014 12:37:47 - DEBUG :: MainThread : Using the following server values:
MBHost: musicbrainz.org ; MBPort: 80 ; Sleep Interval: 1
03-Sep-2014 12:37:47 - INFO :: MainThread : Starting Headphones on http://0.0.0.0:8181/
03-Sep-2014 12:43:11 - INFO :: MainThread : Checking to see if the database has all tables....
03-Sep-2014 12:43:11 - INFO :: MainThread : Retrieving latest version information from github
03-Sep-2014 12:43:12 - INFO :: MainThread : You are running an unknown version of Headphones. Run the updater to identify your version
03-Sep-2014 12:43:12 - INFO :: MainThread : Daemonized to PID: 537
03-Sep-2014 12:43:12 - INFO :: MainThread : Writing PID 537 to /var/run/headphones/headphones.pid
03-Sep-2014 12:43:12 - DEBUG :: MainThread : Using the following server values:
03-Sep-2014 12:43:12 - INFO :: MainThread : Starting Headphones on http://0.0.0.0:8181/
