jjmcmahon7
Apr 24, 2014Aspirant
HeadPhones for RN314 OS 6
I just got a ReadyNAS 314 with OS 6.1.7 on it and i attempted to load Headphones from the following site: https://rnxtras.com/addons/headphones-readynas-6-all I used these plugins previously on ...
zarz83
Oct 12, 2014Aspirant
Hello there,
I have found that when you first install headphone it attempts to connect to port 8282 eg: http://yournasip:8282
The problem is that it is actually on port 8181. This will conflict with other apps that use port 8181 eg Transmission.
Best practice I found is to turn off transmission, load turn headphones on and go to http://yournasip:8181. Headphones will load. After this go into settings and change the port from 8181 to 8282 so that when you press the launch button in Readynas it will open the right port.
Hope this helps. :)
Hope this helps. :)
