ahagelthorn's avatar
ahagelthorn
Help with raid or whatever
hi, i have a readynas 104. i have 2 hdd, one of 1.5 tb and one of 500 gb. i want 2 volumes, one on each disk. but then when I buy a new hard drive and insert it. do I want this to only expand the data storage on one of the volumes. Can someone tell me how i configure this? I don't need a data protection because I have backup elsewhere.
    You can't expand storage with a jbod volume.  What you'll need to do is destroy the volume, remove the old disk, and then insert the new one.  Then create a new volume (which can have the same name), recreate the shares, and restore the data from your backup.
  • StephenB's avatar
    • ahagelthorn's avatar
      ahagelthorn
      Thanks for reply. But i read somewhere when you use x-raid it sounds like just install a new disk and then the readynas will configure it so i can use the new disk too?
      • StephenB's avatar
        If you have two volumes, then you aren't using X-RAID.  You must be using FlexRAID.  You can check this by looking at the X-RAID control on the volume page of the web ui.  If it has a green stripe, then you are using X-RAID (and would only have one volume of 500 GB).
        FWIW, since you have two empty bays, you could also just add the third disk, and create a third volume on it.  Then move some shares to that volume (or create new ones).
  • Ok, thanks for answer,
    I also have a readynas 102 but on it I only have a 1 tb disk and it feels unnecessary to have 2 different devices that are half full so therefore I thought to remove my readynas 102 and just use 104, unfortunately 102 has started to warn about ata error and so I want to transfer everything from that hard drive to another 1.5 tb sitting in the 104, but also use a 500 gb one because I had one lying around but maybe that's stupid? maybe should ignore 500 gb completely. (at the moment they are completely formatted and emptied and so I thought I would start from scratch with my 104) but I want to somehow separate different things using volumes (was thinking of having one volume for monitoring at home and another for backups from computers and so on) the best would of course be to do as written, buy brand new hard drives with the same capacity and hardware but it will be quite expensive
    • StephenB's avatar
      A single 4 TB NAS purposed disk would hold all your data.  US Amazon costs at the moment are about $83 for either a Seagate Ironwolf or a WD Red Plus drive (both of which are well matched to your NAS).
