adb1
Aug 17, 2014Aspirant
Help with Twonky versions
I am using Twonky 7.0.11 from Super Poussin. When the NAS boots, it does not start and I have to enable it manually from the addons page. I've been digging into /etc/frontview/services to try to un...
adb1
Aug 22, 2014Aspirant
super-poussin wrote: because you are lucky guys 7.2.8 is in my dropbox in community section under x86 4.2 directory
I installed it but it won't start. Running it manually I get
surire:/usr/local/TwonkyVision# /usr/local/TwonkyVision/twonkyserver -- -appdata "/c/twonkymedia"
Twonky Version 7.2.8
For image conversion and scaling the TwonkyServer utilizes ImageMagick. For details on the license please see /usr/local/TwonkyVision/cgi-bin/convert-readme.txt
No personal TLS certificate found in /c/twonkymedia/tls.pem! Will use built-in keys (this is insecure)! You have been warned ...
libgcc_s.so.1 must be installed for pthread_cancel to work
Aborted
Checking the libs, I noticed that ldd on 7.0.11 shows
twonkyserver:
linux-gate.so.1 => (0xffffe000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf76fb000)
libc.so.6 => /lib/libc.so.6 (0xf75bd000)
/lib/ld-linux.so.2 (0xf771a000)
but on 7.2.8 it shows
twonkyserver:
linux-vdso.so.1 => (0x00007fffb091f000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007effd0f7d000)
libc.so.6 => /lib64/libc.so.6 (0x00007effd0c0c000)
/lib64/ld-linux-x86-64.so.2 (0x00007effd1199000)
I don't appear to have a libgcc_s.so.1 in /lib64, although there is on in /lib. I tried a symlink, but no luck.
Any ideas?
Cheers
Antony
