edalquist
Aug 04, 2014Apprentice
HowTo: Compile ffmpeg on OS6
I needed more codec support than the version of ffmpeg available in the default package manager provided. The following instructions worked for me to compile and install ffmpeg with all of the codecs ...
amc_oldsarge
Oct 05, 2014Guide
Edalquist,
I am attempting to install ffmpeg (on OS6) per your instructions, but hitting a snag and wonder how you addressed it.
When executing this:
apt-get install -y libmp3lame-dev
I get the following error:
The following packages have unmet dependencies:
libmp3lame-dev : Depends: libmp3lame0 (= 1:3.99.5-dmo3) but 3.99.5+repack1-3 is to be installed
Everything was clean up to that point.
Any ideas on addressing it?
Thanks!
Thanks!
