edalquist
Aug 04, 2014Apprentice
HowTo: Compile ffmpeg on OS6
I needed more codec support than the version of ffmpeg available in the default package manager provided. The following instructions worked for me to compile and install ffmpeg with all of the codecs ...
edalquist
Oct 12, 2014Apprentice
I'm not really sure, I'd probably look into apt-get options to see if you can force the install even with the version miss-match.
