NASty1
May 03, 2016Aspirant
Installing SoftEther on Readynas 31400
Downloaded "VPN Server by poisson" to my NAS. Went through RAIDAR to the vpnserver share and and started the install procedure. When it finished..., I found that it had installed onto my PC and not...
- May 12, 2016
Hi NASty1,
Kindly mark this thread solved for the meantime and post another one if you need assistance with VPN, add-ons or services of your ReadyNAS system. We look forward to hearing from you and we also hope that you will be a valuable contributor in the future.
Kind regards,
BrianL
NETGEAR Community Team
May 03, 2016Guru - Experienced User
Please post the download link you used.
NASty1
May 06, 2016Aspirant
Changed my mind about installing SoftEther. I'am going to forego installing it for now. But thank you!
- BrianL2May 12, 2016NETGEAR Employee Retired
Hi NASty1,
Kind regards,
BrianL
