jpearn
Oct 25, 2017Star
Missing GPL Source for ReadyNAS 6.8.1
As in the title, the firmware 6.8.1 for ReadyNAS has been out for a couple of weeks however there is no GPL source listed on the download page (or if you change the filename to reflect 6.8.1) Could ...
- Oct 27, 2017
I ended up using the connect.c from the previous source GPL and replacing in fs/cifs to get the compile OK
gdeguillebon
Oct 26, 2017Star
with GPL for 6.9.0
http://www.readynas.com/contributed/mdgm/tmp/ReadyNASOS_V6.9.0_WW_src.zip
The build failed..
LD fs/case/built-in.o
CC fs/cifs/cifsfs.o
CC fs/cifs/cifssmb.o
CC fs/cifs/cifs_debug.o
CC fs/cifs/connect.o
In file included from include/linux/kernel.h:13:0, from include/linux/list.h:8, from include/linux/wait.h:6, from include/linux/fs.h:5, from fs/cifs/connect.c:21: fs/cifs/connect.c: In function ‘server_unresponsive’: fs/cifs/connect.c:510:34: error: ‘struct TCP_Server_Info’ has no member named ‘echo_interval’ server->hostname, (2 * server->echo_interval) / HZ); ^ include/linux/printk.h:410:50: note: in definition of macro ‘pr_debug_ratelimited’ __dynamic_pr_debug(&descriptor, pr_fmt(fmt), ##__VA_ARGS__); \ ^ fs/cifs/connect.c:509:3: note: in expansion of macro ‘cifs_dbg’ cifs_dbg(VFS, "Server %s has not responded in %lu seconds. Reconnecting...\n", ^ In file included from fs/cifs/connect.c:49:0: fs/cifs/connect.c:510:34: error: ‘struct TCP_Server_Info’ has no member named ‘echo_interval’ server->hostname, (2 * server->echo_interval) / HZ); ^ fs/cifs/cifs_debug.h:58:23: note: in definition of macro ‘cifs_dbg’ cifs_vfs_err(fmt, ##__VA_ARGS__); \ ^ In file included from include/linux/kernel.h:13:0, from include/linux/list.h:8, from include/linux/wait.h:6, from include/linux/fs.h:5, from fs/cifs/connect.c:21: fs/cifs/connect.c:510:34: error: ‘struct TCP_Server_Info’ has no member named ‘echo_interval’ server->hostname, (2 * server->echo_interval) / HZ); ^ include/linux/printk.h:410:50: note: in definition of macro ‘pr_debug_ratelimited’ __dynamic_pr_debug(&descriptor, pr_fmt(fmt), ##__VA_ARGS__); \ ^ fs/cifs/connect.c:509:3: note: in expansion of macro ‘cifs_dbg’ cifs_dbg(VFS, "Server %s has not responded in %lu seconds. Reconnecting...\n", ^ scripts/Makefile.build:258: recipe for target 'fs/cifs/connect.o' failed make[2]: *** [fs/cifs/connect.o] Error 1 scripts/Makefile.build:403: recipe for target 'fs/cifs' failed make[1]: *** [fs/cifs] Error 2 Makefile:964: recipe for target 'fs' failed make: *** [fs] Error 2
gdeguillebon
Oct 27, 2017Star
my script
#!/bin/bash # required # apt-get install build-essential libncurses5-dev libncursesw5-dev bc # how to use it:
# To build current version
# $ ./build_readynas.sh
# or to build a specific version
# $ ./build_readynas.sh 6.8.0
if [ -z "$1" ]; then rn_version=`awk -F, '{ for(i = 1; i <= NF; i++) { if($i~/version/) print $i} }' /etc/os_version | awk -F'=' '{print $2}'` READYNAS_OS="ReadyNASOS_V"$rn_version"_WW_src" else READYNAS_OS="ReadyNASOS_V"$1"_WW_src" fi ARCH=`uname --machine` KERNEL="linux-*-$ARCH" echo echo "****************************" echo "* $READYNAS_OS" echo "* $ARCH" echo "* $KERNEL" echo "****************************" echo # Download source from official repo wget https://www.downloads.netgear.com/files/GPL/$READYNAS_OS.zip if [ ! -f $READYNAS_OS.zip ]; then # Try temporary repo echo "Download failed with official repo !!" echo "try with another one" wget http://www.readynas.com/contributed/mdgm/tmp/$READYNAS_OS.zip if [ ! -f $READYNAS_OS.zip ]; then echo "File not found! ($READYNAS_OS.zip)" exit 1; fi fi mkdir $HOME/$READYNAS_OS unzip $READYNAS_OS.zip -d $HOME/$READYNAS_OS cd $HOME/$READYNAS_OS/$KERNEL cp $HOME/$READYNAS_OS/$KERNEL/arch/x86/configs/readynas_defconfig .config && make clean && make menuconfig && make && make all #sudo make modules_install #sudo reboot
READYNAS_OS=ReadyNASOS_V6.9.0_WW_src
ARCH=x86_64
KERNEL=linux-*-x86_64
