cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- CampusLuminarySeems to be quite low. My E7600 shows around 20.5C but that one runs at 3GHz. Are you sure you really had 50C for the E2160 cpu? Mine had an idle average of 25C.
- HibtekAspirantI'm pretty sure......although I am getting old now
this is my Ultra 6 + which is in the same room, this is a stock unit, running an E5300,................and I have just looked at that, because that was running at 52-57 and now is running at 30-31!
ok, I think I need more coffee.......and maybe an increase in the old medication!
Device Description Status
Disk 1 Seagate ST2000DM001-9YN164 1863 GB , 40 C / 104 F , Write-cache ON OK
Disk 2 Seagate ST2000DM001-9YN164 1863 GB , 41 C / 105 F , Write-cache ON OK
Disk 3 Seagate ST2000DM001-1CH164 1863 GB , 37 C / 98 F , Write-cache ON OK
Disk 4 Seagate ST2000DM001-1CH164 1863 GB , 34 C / 93 F , Write-cache ON OK
Fan SYS 937 RPM OK
Fan CPU 2057 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 31 C / 87 F [Normal 0-85 C / 32-185 F] OK
UPS 1 Not present NA
The Ultra 4 + is running about normal though
Disk 1 WDC WD20EARS-00MVWB0 1863 GB , 34 C / 93 F , Write-cache ON OK
Disk 2 WDC WD20EARS-00MVWB0 1863 GB , 35 C / 95 F , Write-cache ON OK
Disk 3 WDC WD20EARX-00PASB0 1863 GB , 33 C / 91 F , Write-cache ON OK
Fan SYS 1800 RPM OK
Temp CPU 52 C / 125 F [Normal 0-80 C / 32-176 F] OK
Temp SYS 37 C / 98 F [Normal 0-65 C / 32-149 F] OK
Any idea how to create load on the cpu? - fastfwdVirtuoso
Hibtek wrote: Any idea how to create load on the cpu?
Open one terminal window per CPU, and in each one type:cat /dev/urandom > /dev/null
- CampusLuminaryI test my system by compiling my large code base which stress tests the system for about 30 minutes. In addition I downloaded the stress command line utility from https://github.com/cooljeanius/stress-1.0.4 which can also put some load on your cpu.
- HibtekAspirant:-) I ran the cat /dev/urandom > /dev/null and it only did one processor, never though its as simple as just opening two sessions :-)
Ran it on both, and temp climbed up to 34c, left it for 5 mins and it reached 36c, stopped them and it dropped by 10c by the time I refreshed frontview :-)
Fan did not appear to change from 928 rpm though, but I guess its not getting hot enough to speed it up?
Thanks - CampusLuminaryLet it run for at least 30 minutes to get enough heat into the case to really stress test everything. Both fans should run at max speed then.
- HibtekAspirantWell, after about 30 mins, no fan change and the processor is 36.5!, is there anyway the NAS could read the processor wrong?, a bit late to mention, but I am running RAIDiator 4.2.25
Disk 1 Seagate ST31000528AS 931 GB , 36 C / 96 F , Write-cache ON OK
Disk 2 SAMSUNG HD103UJ 931 GB , 34 C / 93 F , Write-cache ON OK
Fan SYS 902 RPM OK
Fan CPU 2109 RPM OK
Temp CPU 36.5 C / 97 F [Normal 0-60 C / 32-140 F] OK
Top
top - 23:18:00 up 22:54, 3 users, load average: 2.09, 2.05, 1.83
Tasks: 88 total, 3 running, 85 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.0%us,100.0%sy, 0.0%ni, 0.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 2053780k total, 1916756k used, 137024k free, 28432k buffers
Swap: 524272k total, 0k used, 524272k free, 1664440k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1546 root 20 0 3760 496 412 R 100 0.0 30:33.90 cat
1547 root 20 0 3760 496 412 R 100 0.0 30:30.10 cat
29875 root 20 0 2328 1020 788 R 0 0.0 0:02.98 top
I will reapply the firmware and see how it goes - CampusLuminaryHere are my numbers:
Idle:
Fan SYS 942 RPM OK
Fan CPU 1622 RPM OK
Temp SYS 56 C [Normal 0-65 C / 32-149 F] OK
Temp CPU 24 C [Normal 0-60 C / 32-140 F] OK
With stress load:
Fan SYS 998 RPM OK
Fan CPU 2960 RPM OK
Temp SYS 59 C [Normal 0-65 C / 32-149 F] OK
Temp CPU 48 C [Normal 0-60 C / 32-140 F] OK - HibtekAspirantThanks for the reply, it makes me feel better that its similar to others, I have not seen a processor at 16c for a long time! :-)
I did the old finger test as well, when I first saw it so low, and the heat sink was cold or cool to the touch. - dhlLuminaryHi All,
Been reading this thread with great interest. I have two ReadyNAS Pro Pioneer systems that were purchased in 2010. We're about to do a complete disk swap with new 4TB drives to get higher capacity and dual redundancy. I'm thinking this might be a great time to breath new life into the systems with a CPU swap as well. Prices on eBay are dirt cheap and since these machines are at the end of their warranty life, I'm temped to go for it!
A few questions:
Seems like motherboard version makes a big difference in what CPUs will work. Is there an easy way to find out what my motherboard rev# is without opening the case?
For a 2010 Pro, is there any consensus on what processor will work best? I have one main goal - maximum speed without increasing temperatures while keeping all stock cooling (fans and heatsinks). My current system typically reports:
Fan SYS 897 RPM
Fan CPU 1917 RPM
Temp SYS 56 C / 132 F [Normal 0-65 C / 32-149 F]
Temp CPU 37.5 C / 99 F [Normal 0-85 C / 32-185 F]
I'd like it to stay at this level or cooler after the upgrade.
The E6400, E6600 or E6700 seem solid. Or maybe the E7400 or e7600? Or…?
Our systems have 4GB RAM (HCL compatible) and are running the latest BIOS (07/26/2010 FLAME6-MB V2.0)
Any advice/recommendations/gotchas?
Thanks!
