cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- fastfwdVirtuoso
dhl wrote: I have one main goal - maximum speed without increasing temperatures while keeping all stock cooling (fans and heatsinks).
E6600 will give you that, especially if you get the right S-Spec number (SL9ZL, not SL9S8). - dhlLuminary
fastfwd wrote: E6600 will give you that, especially if you get the right S-Spec number (SL9ZL, not SL9S8).
Great, I'm seeing a bunch of them on eBay, many >$20 :D
So is this essentially a plug and play operation - i.e. no firmware hacks or cooling mods needed, just swap and go? - dsm1212ApprenticeHave some fresh thermal paste on hand and while you are in there blow out the fan thoroughly. I actually saw my temps drop a bit but I think it was because of the cleaning :-). I'm using an e7600 I bought on ebay. That processor was frequently removed from a mac and updated so there are quite a few used around.
steve - dhlLuminary@dsm1212
Yes, will do on the thermal paste. Really great that you're seeing *cooler* temps! Do you know the S-Spec number number for your e7600? Really great that you're seeing *cooler* temps! - dsm1212ApprenticeSLGTD was the E7600 spec variant. My results are on page 10 of this topic. Wasn't hugely cooler, about 3 degrees.
- Hi guys,
I would like to do a cpu mod on my Readynas Pro Business Edition (BIOS 07/26/2010 FLAME6-MB V2.0). Sticker on mobo is FA5.
Has anyone tried a q6600 and e7600? Which one should I opt for? I would like to do video transcoding using Plex or AirVideo preferably.
Thanks. - sander11AspirantI just took the plunge and upgraded (again!) to a q6600 from an original upgrade to an e7400. After upgrading the enclosure.db it appears to be working normally, albeit a little hotter and noisier than it did before.
I'm still digging around to see if this is something where I messed up somewhere or this is the new normal. I was initially very reticent about the procedure, but modern cpu switching is pretty painless. From my experience the e series upgrade is generally a drop in which will run cooler, whereas the q chip requires editing some configuration files and, so far, does run hotter. - How is the overall performance of the q6600 in terms of file copying and transcoding of 1080p movies?
Thanks - I have now upgraded my Readynas Pro with a Q6600 and it screams. I can transcode blu-ray at 5120 kbits/s using the Air Video without any jittering or interruptions whatsoever.
Here are how my temp and fan readings while idle:
Fan SYS 856 RPM OK
Fan CPU 1854 RPM OK
Temp SYS 54 C / 129 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 27 C / 80 F [Normal 0-85 C / 32-185 F] OK
Here are how my temp and fan readings while transcoding one stream at 5120:
Fan SYS 922 RPM OK
Fan CPU 3182 RPM OK
Temp CPU 45 C / 113 F [Normal 0-85 C / 32-185 F] OK
hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 8410 MB in 2.00 seconds = 4211.72 MB/sec
Timing buffered disk reads: 1208 MB in 3.00 seconds = 402.16 MB/sec
HTOP
1 [||||||||||||||||############################96.7%] Tasks: 64, 56 thr; 6 running
2 [||||||||||||||||||||||||||##################91.4%] Load average: 3.36 1.19 0.89
3 [||||||||||||||##############################94.0%] Uptime: 03:24:04
4 [||||||||||||||||||||||||####################96.7%]
Mem[|||||||||||||||#**********************1164/3956MB]
Swp[ 0/2047MB]
I hope this helps any of you who are toying with the idea of upgrading your Readynas Pro to a Q6600. For $70 from ebay, it's sweet indeed! - dhlLuminaryWell that was easy! :D
Dropped in a E6700 SL9ZF purchased on eBay for $23. Took about 2 minutes (I spent more time cleaning the enclosure).
BEFORE CPU:ReadyNAS_Pro:/# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
stepping : 13
cpu MHz : 1795.269
cache size : 1024 KB
AFTER CPU:ReadyNAS_Pro:/# cat /proc/cpuinfo
processor : 0
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
stepping : 6
cpu MHz : 2660.311
cache size : 4096 KB
BEFORE - timed reads (best of 10)ReadyNAS_Pro:/# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 2520 MB in 2.00 seconds = 1260.87 MB/sec
Timing buffered disk reads: 396 MB in 3.00 seconds = 131.91 MB/sec
AFTER - timed reads (best of 10)ReadyNAS_Pro:/# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 9502 MB in 2.00 seconds = 4759.45 MB/sec
Timing buffered disk reads: 436 MB in 3.03 seconds = 143.73 MB/sec
BEFORE - temperatures and fansFan SYS 897 RPM OK
Fan CPU 1971 RPM OK
Temp SYS 56 C / 132 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 38.5 C / 101 F [Normal 0-85 C / 32-185 F] OK
AFTER - temperatures and fansFan SYS 932 RPM OK
Fan CPU 2083 RPM OK
Maybe it's my imagination but Frontview seems much snappier. So does connecting and viewing files in the Finder.
Great upgrade - totally worth it and recommended! Thanks everyone, for your help! :woot:
