Witzker
Jul 08, 2016Aspirant
MySql for RND 2000 V1
Hi Where can I download MySql for RND 2000 V1 THX FOR LINK regards
Witzker
THX
I tried to download
PppMyAdmin like discribed below
Once MySQL is enabled, there is of course a requirement to create and manage the MySQL databases. If you have enabled root SSH access to your NAS, then you can of course manage MySQL from the command line. For those less adept with commandline access, there is an application called phpMyAdmin (x86 version, sparc version) that can be installed to provide a web based graphical front end to managing MySQL.
Sparc version
But I get a page saying Access Denied?
What have I done wrong?
Where ca I get the richt addons?
Same at here
Installing PHP
PHP support can be enabled by installing one of PHP addons available from the ReadyNAS Community Addons forum. Personally I would recommend the "WhoCares?" PHP 5.2 addons - x86 version, sparc version - as these tend to be compatible with all other addons, have worked well for me over the years and come with the modules required for PHP access to MySQL databases. Other versions of PHP addons may provide additional features that may be required, so check them out.
Jul 09, 2016Guru - Experienced User
The pages are old, the links go back into the original ReadyNAS forum which is now offline.
Can you see this one? https://community.netgear.com/t5/Community-Add-ons-archive/PHPMyAdmin-v2-5/m-p/652229#p114904 If not, I can copy/paste it here if you like. It's a super_poussin add-on.
If you want the ones from WhoCares_, you can find them here: https://rnxtras.com/readynas-os4-sparc
- WitzkerJul 10, 2016AspirantThx for your answer The link leads to a page showing again Access Denied Pls post them as sugested or pls send email with them attached if possible Many thanks
- StephenBJul 10, 2016Guru - Experienced User
My access lets me see it, thx for letting me know that you cannot. The post was made by super_poussin and looks like this:
PHPMyAdmin
- Description: Administrate your Mysql database from a browser.
- Requirements: RAIDiator 4.1.3+ and PHP Addon
- Platform: NV/NV+ - DUO - 1100
- Current Version: 2.3
PHPMy Admin (12/15/2010)
PHPMy Admin (02/20/2009)
- based on multilingual PHPMyadmin version 3.3.8.1
- solve a bug when add-on is disable (notice it takes time to re-enable it)
- PHPMyAdmin can now be disabled
- solve a bug which made Frontview crash (need to add button to disable phpmyadmin now)
- Remove PHP base components
- Installation Notes: you need to install PHP addon if not already done
if you do not have phpinstalled before and the interface did not launch correctly or if you have a message saying mcrypt did not load correctly please reboot your nas!!!
- Screenshots:
- Old Versions:
Removed
Many THX
do i realy need to install php to use mysql admin?
If yes is there a free version?
Regards
Witzker
