Witzker
Jul 08, 2016Aspirant
MySql for RND 2000 V1
Hi Where can I download MySql for RND 2000 V1 THX FOR LINK regards
Jul 10, 2016Guru - Experienced User
My access lets me see it, thx for letting me know that you cannot. The post was made by super_poussin and looks like this:
PHPMyAdmin
- Description: Administrate your Mysql database from a browser.
- Requirements: RAIDiator 4.1.3+ and PHP Addon
- Platform: NV/NV+ - DUO - 1100
- Current Version: 2.3
PHPMy Admin (12/15/2010)
PHPMy Admin (02/20/2009)
- based on multilingual PHPMyadmin version 3.3.8.1
- solve a bug when add-on is disable (notice it takes time to re-enable it)
- PHPMyAdmin can now be disabled
- solve a bug which made Frontview crash (need to add button to disable phpmyadmin now)
- Remove PHP base components
- Installation Notes: you need to install PHP addon if not already done
if you do not have phpinstalled before and the interface did not launch correctly or if you have a message saying mcrypt did not load correctly please reboot your nas!!!
- Screenshots:
- Old Versions:
Removed
Witzker
Jul 10, 2016Aspirant
Many THX
do i realy need to install php to use mysql admin?
If yes is there a free version?
Regards
Witzker
