agoodside
Aug 16, 2016Aspirant
mySQL, PHPMYAdmin and Owncloud
Ok. common problem - no solution. The problem is that these add-ons have been installed but I get an error loggin into phpMyAdmin - #1045 Cannot login to the MySQL server. Tried all the usual, se...
Aug 16, 2016Guru - Experienced User
What ReadyNAS do you have and what firmware is it running?
- agoodsideAug 16, 2016Aspirant
It is a RN 104 FW 6.5.1
Thanks.
- StephenBAug 16, 2016Guru - Experienced User
Be careful on the suggestions you read here- many are for OS 4.x NAS and the advice might not apply to what you have.
I'm not sure the fix is though (I don't use these packages) Have you tried reaching out to WhoCares_ at rnxtras.com? You could also try PMing him here.
- agoodsideAug 17, 2016Aspirant
Yes , have tried to pm but no reply - seems like a dead end here - sad, it looked like some very promising software.
