pduvallet
Feb 07, 2017Aspirant
MySQL starting problem - error code: 22002010000
Hello, With firmware 6.6.1. I cannot start anymore MYSQL : empty resource error. bad nml call. code 220020100. Any solution ? Thank's
JennC
Feb 08, 2017NETGEAR Employee Retired
Hello pduvallet,
What's the version of your mySQL Server app? Maybe try removing and reinstalling it.
pduvallet
Feb 08, 2017Aspirant
High JennC,
I already tried several times to reinstall Mysql 1.0.1. But the problem is still present.
Regards
Pierre
- JennCFeb 10, 2017NETGEAR Employee Retired
Hello pduvallet,
Are you able to launch other apps?
- pduvalletFeb 10, 2017Aspirant
Hello JennC,
Yes, everything is working fine except Mysql. I had to switch Postgres wich is working properly.
Mysql was working Fine some month ago and I wanted to use it again to evaluate Drupal Application wich does not support Postgres.
Regards
Pierre
- mdgm-ntgrSep 04, 2017NETGEAR Employee Retired
Do you still have this problem?
Hello pduvallet,
Let me check with others.
