pduvallet
Feb 07, 2017Aspirant
MySQL starting problem - error code: 22002010000
Hello, With firmware 6.6.1. I cannot start anymore MYSQL : empty resource error. bad nml call. code 220020100. Any solution ? Thank's
pduvallet
Feb 08, 2017Aspirant
High JennC,
I already tried several times to reinstall Mysql 1.0.1. But the problem is still present.
Regards
Pierre
JennC
Feb 10, 2017NETGEAR Employee Retired
Hello pduvallet,
Are you able to launch other apps?
- pduvalletFeb 10, 2017Aspirant
Hello JennC,
Yes, everything is working fine except Mysql. I had to switch Postgres wich is working properly.
Mysql was working Fine some month ago and I wanted to use it again to evaluate Drupal Application wich does not support Postgres.
Regards
Pierre
- mdgm-ntgrSep 04, 2017NETGEAR Employee Retired
Do you still have this problem?
- JennCFeb 10, 2017NETGEAR Employee Retired
Hello pduvallet,
Let me check with others.
