doylmi
Sep 01, 2013Guide
NAS Utils for Android - RAIDiator 4, 5 and OS 6
I've added support for OS6 to NAS Utils for Android. You can find it on Google Play or Amazon
Also new this release:
- Manage multiple NAS devices
- Multiple RAIDiator 4.1 fixes
- SSH (via ConnectBot)
Let me know if you have any issues. Feedback is welcome.
Aside from bug fixes, the next release will most likely focus on updating the UI and general user experience. I'm also looking at CPU/Mem/Disk metrics (possibly integrating w/ iStat) and the ability to start/stop services.
- doylmiGuideLatest release is out, with multiple bug fixes and a new UI.
- doylmiGuideVersion 3.1 is out
- Support for the EDA500 expansion
- Fixed SMART+ display for devices with dark themed dialogs
- Fixed issue where logs did not display for certain locales
- Small patches and bug fixes - doylmiGuideVersion 3.2 is out tonight
- Start, stop and manage running services
- Launch FTP browser
- Status screen improvements (recalibrate fans, volume status, support for bonded interfaces...)
- Small bug fixes and enhancements - euphosAspirantAny reason why this app isn't compatible with GoogleTV devices? Can I side-load it?
- doylmiGuide
euphos wrote: Any reason why this app isn't compatible with GoogleTV devices? Can I side-load it?
Not sure. It's a small change to the Android manifest for it to show up in the Play store, but I would have to test it out and make sure I'm not using any APIs that are not available on Google TV, and that everything works without a touch screen. One thing I will say, is that I haven't invested much time at this point into how the app looks in landscape mode. So it's definitely not optimized for displaying on a TV from that perspective.
I've logged a ticket for Google TV support: http://bit.ly/KSdgDa. Right now, I'm working on support for iStat, which has been a fairly common request. After that, I can take this up. - doylmiGuideVersion 3.3 is out
- iStat integration (CPU, Memory and Network utilization stats in real time)
- ReadyDATA support - doylmiGuide@euphos - I've quietly enabled support for Google TV. I had a tough time getting an emulator working, so it's not tested. Try it out and let me know how it goes.
- doylmiGuideVersion 3.3.2 is out
- Better user experience for initial iStat set up
- Small bug fixes and enhancements - doylmiGuide
doylmi wrote: @euphos - I've quietly enabled support for Google TV. I had a tough time getting an emulator working, so it's not tested. Try it out and let me know how it goes.
You ever end up giving this a try? - doylmiGuideVersion 4.0 is out, adding official support for the NV+ v2 and Duo v2 (RAIDiator 5). This release also fixes an issue where Fahrenheit temperatures were not always reported accurately.
http://bit.ly/1aDvkgR
