darthy
Dec 13, 2014Apprentice
Netgear Syslog Server
Hi, I just installed the Netgear Syslog Server on my ReadyNAS 314 but can't find any guides on how to send the ReadyNAS syslog events to the syslog server. If someone could point my in the right direc...
jbernardo
Apr 22, 2015Apprentice
Since ReadyNAS is running systemd, you are out of luck with syslog. Systemd uses it's own binary logging format. I've been told that there is a way to configure systemd to also forward the logs to syslog, so you might be able to do something if you enable ssh and start messing with systemd configuration.
